Belkin Lightning Audio + Charge RockStar - Lightning to Headphone
Quicklinx: DK04WS00 Mfr#: F8J212BTWHT
Marketing description is not available.
  • Dual functionality
    Powerful pass-through charging powers up your iOS device at maximum speed. So, whether you're listening to music or watching videos, using audio navigation, or taking calls while you charge, there's nothing slowing you down.
  • 3.5 mm audio
    The Belkin F8J212 supports any audio jack using the 3.5mm connector with up to 48 kHz, 24-bit audio output for clear conversations and flawless music playback.
  • Case compatible
    There's no need to remove your iPhone or iPad case to connect your 3.5mm headphones or your charging cable, since the Belkin F8J212 works with most cases.
Belkin 3.5 mm Audio + Charge RockStar - Lightning to headphone jack / charging adapter - Lightning / audio
Cable
White
Connectors
Lightning - male
Connectors (Second End)
Lightning - female , 4-pole mini jack - female
Rated Current
2.4 A
Sync and charge
Cable Type
Interface Supported
Lightning / audio
Rated Current
2.4 A
Recommended Use
Phone, tablet
Sync and charge
White
Connectors
Apple Lightning - male
Apple Lightning - female , Mini-phone 3.5 mm 4-pole - female
MFI
