The Mini DisplayPort to HDTV display cable lets you stream high-quality A/V content from your laptop or tablet to your HDTV. Use it to watch movies, share photos, or expand your workstation with a mirrored desktop.
Durable 6-foot cable
The cable's molded strain-relief design reduces strain on the cable to help prevent wear and tear. Its 6-foot length is ideal for connecting to hard-to-reach HDMI inputs on your HDTV. -
Plug-and-Play wherever you go
Seamless Plug-and-Play capability makes this cable ideal for quick media sharing in any setting. The cable has the design that helps you easily identify the "right side up" insertion point.
- Belkin adapter cable - DisplayPort / HDMI - 1.8 m
- Cable
- Adapter cable - DisplayPort / HDMI
- Length
- 1.8 m
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- HDMI - male
- Moulded, strain relief
- Cable Type
- Adapter cable
- Interface Supported
- Length
- 1.8 m
- Connector
- 19 pin HDMI Type A - male
