Belkin Grip Candy SE for Galaxy S6 - Clear/Blacktop
Quicklinx: BGB1WS00 Mfr#: F8M938btC00
Belkin believes rugged protection doesn't have to be overpowering, and that you shouldn't have to choose between a case that gives you peace of mind and one that fits in your pocket. Strength truly comes from smart design. That's why each of the Galaxy S6 Protective Cases have gone through a design evolution, making the typical bulky protective case a thing of the past.
  • Dimpled edges for added grip
    The best way to protect your phone is to prevent the chance of damage in the first place. Belkin has revamped the design of the signature color-contrasting edges of the Belkin Grip Candy SE case so your Galaxy S6 is even easier to hold. The dimpled texture feels great in hand, and gives you the added security and stabilization you need to prevent accidental drops.
  • Bulk-free damage defense
    The Belkin Galaxy S6 Grip Candy SE Case is made of a semi-flexible material that clings to your Galaxy S6 like a shock-absorbent second skin. When you put the Belkin Grip Candy SE case on your Galaxy S6, you'll notice that the edges of the case wrap around your phone ever so slightly. Belkin designed the case this way so when you place your phone face down on a flat surface, your screen is less likely to get scratched - but it's still just as easy to get in and out of your pocket or bag.
  • Easy to take on & off
    Unlike other extreme protection cases, the Grip Candy SE's flexible material makes it quick and easy to take on and off. Now you can change your case as often as you change your look.
  • Full camera & port access
    The Belkin Grip Candy SE case is designed to protect the buttons on the sides of your Galaxy S6, while keeping the ports and speakers fully exposed. Adjusting your volume, plugging in your headphones, and connecting your charging cable is fast and easy - all while keeping your case on and your phone fully protected.
Belkin Grip Candy SE - back cover for mobile phone
Back cover for mobile phone
Clear, blacktop
Samsung Galaxy S6
Clear, blacktop
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Shockproof, scratch-resistant
Cover Type
Back cover
Camera lens cutout, rugged, raised edges, button covers
Samsung Galaxy S6
