Belkin 20K Power Bank USB-A & C 15W Black
Quicklinx: GWSPWS00 Mfr#: BPB012BTBK
Device Type: Power Bank USB-A & C 15W Black
Type: Power Bank
Product Range: Belkin BoostCharge
Product Model: PowerBank 8000
34 In Stock
£24.01 ex VAT
£28.81 inc VAT
Charge up to 3 devices at the same time with Belkin compact and powerful Power Bank 20K. It has 2 USB-A ports and 1 USB-C port, delivering a total of up to 15W when using all 3 ports.
  • Power 3 devices
    Plug into portable power for up to three devices at the same time with its USB-C port and 2 USB-A ports.
  • Cable included
    Start charging immediately. Belkin Power Bank comes with a USB-A to USB-C cable so you can start charging right out of the box.
  • LED indicator light
    LED battery indicator lights let you know when it's time to charge or when you're good to go.
Belkin BoostCharge power bank - 24 pin USB-C, 2 x USB - 15 Watt
Power bank
8 cm x 15.94 cm x 2.276 cm
508 g
Output Connector Type
Total 3: 24 pin USB-C, 2 x USB - on cable: USB-C
DC 5 V
Voltage Provided
5 V
Max Electric Current
3 A
20000 mAh
Power Provided
15 Watt
Cables
USB-A to USB-C power cable - 15.2 cm
Power bank
Tablet, mobile phone
8 cm
15.94 cm
2.276 cm
508 g
Enclosure Colour
DC 5 V
Input Connectors
24 pin USB-C
Input Connectors Qty
1
Voltage Provided
5 V
Output connectors
Total 3: 24 pin USB-C, 2 x 4 pin USB Type A
Power Provided
15 Watt
Detachable Cable Connector Type
USB-C
3 A
LED indicators, sleep mode
20000 mAh
Equipment Protection Value
2500 US Dollars
RoHS, REACH
Type: Power Bank
Brand: Belkin
