Belkin Cat6 Snagless STP Patch Cable (Blue) 3m
Customer rating: 4.0* (Write a review)
Quicklinx: 3B36WS00 Mfr#: A3L980B03MBL-HS
Upgrade your network with a CAT6 Snagless Networking Cable from Belkin and enjoy clean, clear transmissions. Now you can replace CAT5 cables that don't support 100BASE-T or Gigabit Ethernet and improve the return loss in your current network by 40 percent. Engineered with 50-micron gold-plated connectors to ensure clear transmissions, and snagless molds to protect the RJ45 tabs from damage during installation, this cable meets and exceeds the performance requirements of Category 6.
Belkin patch cable - 3 m - blue
Patch cable - CAT 6
Shielded twisted pair (STP)
Snagless
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Omniview SMB 1x16 KVM-over-IP Switch, SMB 1x8 KVM-over-IP Switch; OmniView SMB CAT5 KVM Switch
Network Cable Type
Patch cable - CAT 6
Impedance
100 Ohm
Plated Connector
Gold
Snagless
Length
3 m
Blue
Connector
RJ-45 - male
RJ-45 - male
Belkin Omniview SMB 1x16 KVM-over-IP Switch, SMB 1x8 KVM-over-IP Switch , Belkin OmniView SMB CAT5 KVM Switch
Customer reviews
Write a review for the Belkin Cat6 Snagless STP Patch Cable (Blue) 3m here!
A great lead if a bit stiff
Reviewed by Phil. Review Posted 21/02/2009
A fine lead with quality connections but rather stiff which loses it one star for me as I like my leads to lie neatly.
  • Overall 4*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
