The Belkin BoostCharge Pro 2-in-1 wireless charging pad is designed for both cellular phones and wireless earphones, featuring Power Delivery 3.1 for fast and efficient charging. Its magnetic Qi2 compatibility enhances the charging experience for MagSafe enabled devices, providing a secure connection every time.
Crafted with the environment in mind, the BoostCharge Pro is made from 60% recycled post-consumer plastic, making it a choice that benefits both your devices and the planet. The pad's user-friendly design includes a non-slip base, case compatibility up to 3 mm, and an LED indicator for charging status at a glance. With the inclusion of a 1.5 m USB-C to USB-C cable, setting up your charging station is straightforward. Choose the Belkin BoostCharge Pro 2-in-1 for a seamless and sustainable charging solution.
Efficient charging
Experience the convenience of fast wireless charging with the Belkin BoostCharge Pro 2-in-1. Its Power Delivery 3.1 technology ensures your devices get the power they need quickly, supporting up to 15 W for wireless charging pads and 30 W for the AC power adapter. -
Designed for compatibility
Tailored to support a wide range of devices, this wireless charging pad is compatible with both cellular phones and wireless earphones. Its magnetic Qi2 feature enhances the charging experience for MagSafe compatible devices, ensuring a secure and efficient power transfer. -
Eco-friendly choice
Committed to sustainability, the Belkin BoostCharge Pro 2-in-1 is made of 60% recycled post-consumer plastic. Choosing this product not only benefits your charging needs but also contributes to a healthier planet. -
User-friendly design
With features like a non-slip base, case compatibility up to 3 mm, and an LED indicator, this wireless charging pad is designed for ease of use. Its magnetic Power Profile (MPP) pad ensures your device stays in place while charging.
- Belkin BoostCharge Pro 2-in-1 wireless charging pad - magnetic with Qi2 - + AC power adapter - 15 Watt
- Product Type
- Wireless charging pad + AC power adapter
- Designed For
- Mobile phone, wireless earphones
- 16.31 cm x 8.18 cm x 1.5 cm
- 420 g
- Black
- Max Electric Current
- 3 A
- Fast Charge Technology
- Power Delivery 3.1
- Wireless Charging Standards
- Qi2
- Power Provided
- 15 Watt
- Power Device Details
- Wireless charging pad - wireless pad - 15 W , Wireless charging pad - wireless pad - 5 W , Wireless charging pad - 24 pin USB-C - 5 W , AC power adapter - 24 pin USB-C - 30 W
- Cables
- USB-C to USB-C cable - 1.5 m
- Product Recycled Content
- 60 % - made of recycled post-consumer plastic
- 2-year warranty
- Product Type
- Designed For
- 16.31 cm
- 8.18 cm
- 1.5 cm
- 420 g
- Enclosure Colour
- Black
- Input Connectors
- 24 pin USB-C
- Input Connectors Qty
- 1
- Power Provided
- 15 Watt
- 3 A
- Wireless charging pad: wireless pad - 15 W , Wireless charging pad: wireless pad - 5 W , Wireless charging pad: 24 pin USB-C - 5 W , AC power adapter: 24 pin USB-C - 30 W
- Wireless Charging
- Qi2
- AC Power Adapter Included
- MagSafe Compatibility
- LED indicator, case compatible (up to 3 mm), fast wireless charging, Magnetic Power Profile (MPP) pad, non-slip base
- Equipment Protection Value
- 1500 British Pounds
- Material
- Plastic
- Cables Included
- RoHS, REACH
- Limited warranty - 2 years
