Belkin BoostCharge 20000 mAh Power Bank - White
Quicklinx: H2QSWS00 Mfr#: BPB003BTWT
The Belkin BoostCharge power bank is designed to keep your cellular phones and tablets powered when you need them the most. With a generous 20,000 mAh capacity, it offers the endurance to support your devices during long trips, busy workdays, or any situation where a power outlet might not be readily available. This power bank is not just about capacity; it also focuses on functionality. It can charge up to two devices simultaneously, thanks to its dual output connectors, and comes with a USB-A to USB-C power cable, ensuring compatibility with a wide range of devices. Safety is a priority, as evidenced by its compliance with REACH, RoHS, and USB-IF standards, alongside an equipment protection value of 2500 US Dollars. Whether you're a professional on the go, a frequent traveler, or simply someone who values the convenience of portable power, the Belkin BoostCharge power bank is an essential companion.
  • Versatile 20,000mAh power
    The 20,000mAh power bank provides up to an additional 28 hours of battery life to your tablet and up to 77 hours to your smartphone. You can stay charged for days while you travel for work or leisure, all without having to plug into a wall outlet. With two USB-A ports, you're ready to charge a wide variety of devices on the go.
  • Charge two devices at once
    Featuring two USB-A ports, our power bank delivers 12W of power when a single port is in use and a total of 15W split between ports when both are used simultaneously.
Belkin BoostCharge power bank - USB - 15 Watt
Power bank
7.47 cm x 15.72 cm x 2.59 cm
480 g
White
Output Connector Type
Total 2: USB - on cable: USB-C
DC 5 V
Voltage Provided
DC 5 V
Max Electric Current
2.4 A
20000 mAh
Power Provided
15 Watt
Power Device Details
Power bank: 2 x - 4 pin USB Type A - output - 5 V - 15 W - 2.4 A , Power bank - 24 pin USB-C - input
Cables
USB-A to USB-C power cable - 15 cm
Power bank
Tablet, mobile phone
7.47 cm
15.72 cm
2.59 cm
480 g
Enclosure Colour
White
DC 5 V
Input Connectors
24 pin USB-C
Input Connectors Qty
1
Voltage Provided
DC 5 V
Output connectors
Total 2: 4 pin USB Type A
Power Provided
15 Watt
Detachable Cable Connector Type
USB-C
2.4 A
Power bank: 2 x 4 pin USB Type A - output - 5 V - 15 W - 2.4 A , Power bank: 24 pin USB-C - input
LED indicator, simultaneously charges up to 2 devices
20000 mAh
Equipment Protection Value
2500 US Dollars
RoHS, USB-IF, REACH
