Belkin 20,000 mAh power bank provides up to an additional 28 hours of battery life to your tablet and up to 77 hours to your smartphone. You can stay charged for days while you travel for work or leisure, all without having to plug into a wall outlet. With two USB-A ports, you're ready to charge a wide variety of devices on the go.
Featuring two USB-A ports, Belkin power bank delivers 12W of power when a single port is in use and a total of 15W split between ports when both are used simultaneously.
- Belkin BoostCharge power bank - USB - 15 Watt
- Product Type
- Power bank
- 7.47 cm x 15.72 cm x 2.59 cm
- 480 g
- Black
- Output Connector Type
- Total 2: USB - on cable: USB-C
- Voltage Required
- DC 5 V
- Voltage Provided
- DC 5 V
- Max Electric Current
- 2.4 A
- Battery
- 20000 mAh
- Power Provided
- 15 Watt
- Power Device Details
- Power bank: 2 x - 4 pin USB Type A - output - 5 V - 12 W - 2.4 A , Power bank - 24 pin USB-C - input
- Cables
- USB-A to USB-C power cable - 15 cm
- 2-year warranty
- Product Type
- Power bank
- Designed For
- Tablet, mobile phone
- 7.47 cm
- 15.72 cm
- 2.59 cm
- 480 g
- Enclosure Colour
- Black
- Voltage Required
- DC 5 V
- Input Connectors
- 24 pin USB-C
- Input Connectors Qty
- 1
- Voltage Provided
- DC 5 V
- Output connectors
- Total 2: 4 pin USB Type A
- Power Provided
- 15 Watt
- Detachable Cable Connector Type
- USB-C
- 2.4 A
- Power bank: 2 x 4 pin USB Type A - output - 5 V - 12 W - 2.4 A , Power bank: 24 pin USB-C - input
- LED indicator, simultaneously charges up to 2 devices
- Capacity
- 20000 mAh
- Equipment Protection Value
- 2500 US Dollars
- Cables Included
- RoHS, USB-IF, REACH
- Limited warranty - 2 years
