Get a fast charge, up to 50% in around 36 minutes with strong braided USB-C to USB-C cables that are built to last. Use them at home, in your car, or anywhere you need to sync music, photos, or data and charge your devices.
Tested to survive 10,000+ bends, and made with double braided nylon, these USB-C fast charge cables stand up to the most rigorous daily use so you don't have to keep replacing them. And with a braided nylon exterior they've got the sturdiness to withstand just about anything. They're also USB-IF certified to make sure you'll always have a superior experience.
Fast charging, quick syncing USB-C cables
Get a fast charge, up to 50% in around 36 minutes with strong braided USB-C to USB-C cables that are built to last. Use them at home, in your car, or anywhere you need to sync music, photos, or data and charge your devices. -
Truly strong cables
- Belkin BOOST CHARGE - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
- USB-C cable
- Sync and charge, braided
- Length
- 1 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- White
- 2-year warranty
- USB-C cable
- Jacket Material
- Nylon
- Length
- 1 m
- White
- Connector
- USB-IF
- 2-year warranty
