Belkin Thunderbolt 3 USB-C - USB-C 2m
Quicklinx: DXSJWS00 Mfr#: F2CD085bt2M-BLK
Thunderbolt, famed for super-fast speeds, high-definition capability, and huge power output, has had an upgrade. Transferring data between Thunderbolt 3 devices extremely fast, this cable is ideal for large-volume data and Ultra HD displays. It also supports high power delivery, and can daisy chain a few Thunderbolt 3 devices. Get the optimal from all your Thunderbolt 3 peripherals with the ultimate smart, high-speed cable.
  • Faster data transfer
    Between Thunderbolt 3 devices, the Thunderbolt 3 cable can support fast data transfer. Backwards compatible, it delivers high speeds for USB 3.1 devices, USB 3.0 and USB 2.0.
  • Supports ultimate high-definition displays
    High-volume data capability makes the Thunderbolt 3 cable ideal for high-definition video. Supporting Thunderbolt, 4K and Ultra HD displays, sharing content between screens is easy, without compromising quality.
  • Stay charged
    The Thunderbolt 3 cable can also supply high power delivery for Thunderbolt 3 and USB-C devices, that require it, without the need for an additional power supply.
  • Great length
    The Thunderbolt 3 cable is a compact solution, ideal for connecting Thunderbolt peripherals, such as docks and hard drives, and fits seamlessly to any desk environment.
Belkin Thunderbolt 3 - Thunderbolt cable - 24 pin USB-C to 24 pin USB-C - 2 m
Thunderbolt cable
Ultra HD (4K) support, 5K support
Length
2 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
USB 3.1 Gen 2 / Thunderbolt 3
P/N: F4U109tt
Thunderbolt cable
Length
2 m
Connector
24 pin USB-C - male
24 pin USB-C - male
USB 3.1 Gen 2 / Thunderbolt 3, FCC
P/N: F4U109tt
