Belkin Boost Charge 20,000mAh USB-C Power Bank
Quicklinx: F660WS00 Mfr#: F7U063btBLK
TRAVEL LIGHTER WITH ONE CABLE
A high capacity power bank designed for USB-C devices including the MacBook, iPad Pro, Surface Pro, and Nintendo Switch. The included USB-C cable supports USB Power Delivery 2.0 30W to rapidly power up your USB-C device and recharge the power bank. Simplify charging and travel light thanks to the convenience of a single cable solution. An additional USB-A port offers faster charging for older devices.
THE BELKIN DIFFERENCE
  • Pioneer in innovation and technology for over 35 years
  • Rigorously tested to ensure safe charging for users and their devices
  • Covered by a 2-year product warranty and a $2,500 Connected Equipment Warranty for total peace of mind
PERFORMANCE DRIVEN
20100 mAh delivers more than a simple battery boost for USB-C devices. It’s enough to deliver up to 28 additional hours of battery life to your MacBook. With this kind of power in your back pocket, staying charged, even for a high-performing device like a MacBook, just got a whole lot easier.
HIGH-CAPACITY POWER BANK WITH POWER DELIVERY
Equipped with USB Power Delivery 2.0, this power bank can charge a MacBook up to 30W. Just connect the included USB-C cable to a 27W wall charger to recharge the power bank. The power bank also has a USB-A port with a 2.4Amp/ 12-watt output, capable of quickly charging iPhone, iPad and other USB-A devices.
SINGLE-CABLE SIMPLICITY
The convenience of a single cable that charges your USB-C devices and recharges the power bank adds simplicity to the charging experience. It reduces the need for multiple, similar-looking cables and saves time and clutter.
SAFETY MATTERS
Belkin batteries include sensors monitoring heat, voltage and circuitry so the power bank will not overheat and harm your devices. Excess heat, voltage fluctuation or circuit abnormalities activate an override that shuts the battery down immediately for ultimate safety.
KEY FEATURES AND BENEFITS
  • LED lights indicate charge level
  • 1 x 12W USB-A to charge faster iPhone, iPad, and other USB-A devices
  • 1 x 30W USB-PD 2.0 input to fast charge power bank
  • 1 x USB-PD 2.0 30W output to fast charge MacBook and other USB-C devices
  • USB-C cable recharges your USB-C device and the power bank
  • Performance driven
    20100 mAh delivers more than a simple battery boost for USB-C devices. It's enough to deliver up to 28 additional hours of battery life to your MacBook. With this kind of power in your back pocket, staying charged, even for a high-performing device like a MacBook, just got a whole lot easier.
  • High-capacity power bank with Power Delivery
  • Single-cable simplicity
  • Safety matters
Belkin BoostCharge power bank - USB, 24 pin USB-C
Power bank
2.32 cm x 7.765 cm x 15.565 cm
394 g
Output Connector Type
Total 2: USB, 24 pin USB-C - on cable: USB-C
Max Electric Current
2.4 A
20100 mAh
Power Device Details
Power bank - 4 pin USB Type A - 12 W - 2.4 A , Power bank - 24 pin USB-C - 30 W
Cables
USB-C cable
Power bank
Portable player, tablet, mobile phone
2.32 cm
7.765 cm
15.565 cm
394 g
Input Connectors
24 pin USB-C
Input Connectors Qty
1
Output connectors
Total 2: 4 pin USB Type A, 24 pin USB-C
Detachable Cable Connector Type
USB-C
2.4 A
Power bank: 4 pin USB Type A - 12 W - 2.4 A , Power bank: 24 pin USB-C - 30 W
LED indicator, voltage monitoring, heat monitoring, circuitry monitoring
20100 mAh
Equipment Protection Value
2500 US Dollars
USB-C cable
