Seamless cursor and keyboard switching allows the user to change automatically from one highly isolated computer system to another as the mouse cursor crosses display borders, without having to push any buttons. Every system remains visible on its own display, continuously and simultaneously, while the Belkin Advanced Secure KM Switch keeps them isolated and secure.
The Belkin Advanced Secure KM Switch is ideal for data-intensive applications where information from multiple secure sources must be viewed and compared on multiple displays in real time. Analysts and operators in defense and intelligence, banking and trading, or complex command and control environments will benefit immediately and immensely from seamless switching with cursor movement.
Seamless Cursor Switching (SCS)
SCS allows the Belkin Advanced Secure KM Switch to transition automatically between highly isolated computers when the mouse cursor crosses the display border. Audio and keyboard will "follow" the mouse from one computer to the next as the cursor moves from screen to screen. -
True data path isolation
Prevent data breach with true data path isolation - purposefully engineered using a single, un-buffered, dedicated processor for each peripheral port. -
Lag-free, real-time switching
Hardware-based solution eliminates keyboard and mouse delay when switching between ports, offering a fluid and uninterrupted user experience. -
Peripherals protection
Eliminate data leaks with hardware-controlled unidirectional data flow that allows primary input devices, such as keyboards and mice, to communicate in only one direction, keeping these devices from receiving any data back from the computer. -
Multi-monitor flexibility
Predefined configurations along with an easy-to-use configuration tool let you configure almost any desired physical display setup, with single, dual, or quad displays connected to each PC.
- Belkin Advanced Secure KM Switch - keyboard/mouse/audio switch - 4 ports - TAA Compliant
- Keyboard/mouse/audio switch - 4 ports
- Subtype
- USB / audio
- Ports
- 4 x keyboard/mouse/audio
- KVM Users Qty
- 1 local user
- Localisation
- United Kingdom
- TAA Compliant
- 3-year warranty
- Enclosure Type
- Desktop
- Subtype
- USB / audio
- Ports
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- PS/2, USB
- Status Indicators
- Port status
- 4 x keyboard (USB) / mouse (USB) Type B , 2 x keyboard (USB) / mouse (USB) Type A , 1 x keyboard (PS/2) , 1 x mouse (PS/2) , 1 x audio output mini-jack , 4 x audio input mini-jack
- Power Device
- External power adapter
- TAA Compliant
- Localisation
- United Kingdom
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
