Belkin Advanced Secure KM Switch - keyboard/mouse/audio switch - 4 ports
Quicklinx: GT5RWS00 Mfr#: F1DN104K-3EA
Seamless cursor and keyboard switching allows the user to change automatically from one highly isolated computer system to another as the mouse cursor crosses display borders, without having to push any buttons. Every system remains visible on its own display, continuously and simultaneously, while the Belkin Advanced Secure KM Switch keeps them isolated and secure.The Belkin Advanced Secure KM Switch is ideal for data-intensive applications where information from multiple secure sources must be viewed and compared on multiple displays in real time. Analysts and operators in defense and intelligence, banking and trading, or complex command and control environments will benefit immediately and immensely from seamless switching with cursor movement.The KM switch is designed, manufactured and certified to the NIAP Protection Profile Ver.3.0 standard. The NIAP Protection Profile ensures agencies are receiving the appropriate security for Keyboard and Pointing Devices, as well as improved audio device security.
  • Dedicated processors with emulators for every port
    Isolated port paths for video and audio to prevent data leaks between computers.
  • Unidirectional data paths
    Optical data diodes prevent peripherals from being used to breach systems.
  • Peripheral management
    USB device detection prevents unauthorized peripheral usage.
  • Anti-tampering
    Internal electrical sensors render unit inoperable if opened.
  • Secure labeling
    Holographic tamper-evident product label provides visual indication and prevention of tampering.
  • Fast switching
    No keyboard or mouse delays when switching ports.
  • High retention connectors
    Semi-locking USB ports prevent accidental disconnection.
  • Uni-body chassis
    Minimizes entry points and prevents physical tampering.
  • Customizable port coloring and naming
    Facilitates port identification and reduces user switching errors.
  • Secure packaging
    Tamper-evident packaging ensures product is not tampered with during transport.
Keyboard/mouse/audio switch - 4 ports
Subtype
KM
Ports
4 x keyboard/mouse/audio
KVM Users Qty
1 local user
AC 120/230 V
31.25 cm x 15.38 cm x 4.75 cm
1.9 kg
Red Hat Linux, Microsoft Windows Server 2003, Apple MacOS X 10.3 or later, Microsoft Windows 2000/XP/Vista/7
3-year warranty
P/N: F1DN102K-3EA
Enclosure Type
Desktop
Subtype
KM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
PS/2, USB
Status Indicators
Port status
4 x keyboard (USB) / mouse (USB) Type B , 2 x keyboard (USB) / mouse (USB) Type A , 1 x keyboard (PS/2) , 1 x mouse (PS/2) , 1 x audio output mini-jack , 4 x audio input mini-jack
External power adapter
AC 120/230 V
FCC Class B certified, UL, RoHS, ICES, EAL 2+
31.25 cm
15.38 cm
4.75 cm
1.9 kg
Limited warranty - 3 years
0 - 80% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
P/N: F1DN102K-3EA
