Belkin 20W Single Port Wall Charger - White
Quicklinx: G5S4WS00 Mfr#: WCA003myWH
This compact wall charger with USB-Power Delivery means fast charging for your USB-PD-enabled devices. It supports Fast Charge for iPhone to charge iPhone 8 or later from zero to 50% in 30 minutes and other smartphones/tablets at optimal speeds. Purposefully designed to be travel-friendly, this pocket-sized charger easily fits to any environment at home or when you're out and about.
  • Supports Fast Charge for iPhone
    With USB-Power Delivery on board, this charger supports Fast Charge to charge your iPhone battery from 0-50% in only 30 minutes, and other compatible devices at optimal speeds.
  • Seriously small
    This compact charger sits flat to the wall to fit easily behind furniture or in hard-to-reach outlets. It's also perfectly-sized to fit in a pocket or bag, which means you'll have access to fast charging wherever you're headed.
Belkin BoostCharge Wall Charger power adapter - 24 pin USB-C - 20 Watt
Power adapter
5 cm x 4.875 cm x 5.23 cm
White
Output Connector Type
24 pin USB-C
Max Electric Current
3.6 A
Fast Charge Technology
Fast Charge, Power Delivery
Power Provided
20 Watt
Power adapter
Tablet, mobile phone
5 cm
4.875 cm
5.23 cm
Enclosure Colour
White
Output connectors
24 pin USB-C
Power Provided
20 Watt
3.6 A
Equipment Protection Value
2500 US Dollars
USB-IF, MFI
