Never suffer from the dreaded low battery again. Belkin mobile chargers are able to charge the greatest number of devices on market, making them the only chargers you'll ever need. The sleek, compact design is not only easy on the eyes, but you can plug it in virtually anywhere, so a battery boost is always in reach whenever you need it.
Rapid data transfer speed
The Belkin USB 3.0 micro-B cable provides 5 Gbps transfer speeds, up to 10x faster than USB 2.0. SuperSpeed USB 3.0 also offers faster device charging than USB 2.0. Galaxy smartphones and tablets with USB 3.0 support up to 2x faster data transfer so you can sync your photos, music and data at blazing fast speed. The cable is also backwards compatible with USB 2.0. -
Compatible with the most mobile devices
The USB port is universal, so you can plug in any USB charging cable to charge a variety of different mobile devices at the fastest possible speed, including any brand smartphone, any brand tablet or any another mobile device. -
Sleek, compact design
The Belkin universal car charger is extremely fast, but it's also extremely small. Plug it into your dash and it seamlessly blends in with your car's interior. It weighs less than a few quarters in your pocket. -
Passenger-friendly
Use the versatile Belkin car charger with your own USB cable to charge and sync your phone or tablet. Or plug in your Samsung 30-pin or micro-USB cable to charge other Galaxy devices. It's the best charger for when you or your passengers have different devices to charge. -
Belkin safety assurance: charge with confidence
Every time you plug your smartphone or tablet into a Belkin mobile charger, you never have to worry about things like power spikes or storms damaging your valuable mobile device. Intelligent circuitry with built-in voltage sensing detects and responds your device's power needs, while safety features ensure that your devices are protected. The quality teams go above and beyond for consumer and environmental safety, setting standards above the minimum requirements and putting each product through the own set of rigorous quality assurance tests.
- Belkin Car Charger car power adapter - USB - 10 Watt
- Product Type
- Car power adapter
- Black
- Output Connector Type
- USB - on cable: Micro-USB
- Max Electric Current
- 2.1 A
- Power Provided
- 10 Watt
- Cables
- Micro-USB cable - 91.44 cm
- Designed For
- Samsung Galaxy Note 3, NotePRO (12.2 in), S5, TabPRO (12.2 in)
- Product Type
- Car power adapter
- Designed For
- Tablet, mobile phone
- Enclosure Colour
- Black
- Input Connectors
- Automobile cigarette lighter
- Input Connectors Qty
- 1
- Output connectors
- 4 pin USB Type A
- Power Provided
- 10 Watt
- Detachable Cable Connector Type
- Micro-USB Type B
- 2.1 A
- Cables Included
- Designed For
