Belkin 10,000 mAh Power Bank 1x USB-C 2x USB-A - Black
Quicklinx: G5RHWS00 Mfr#: F8J267btBLK
The Power Bank 10K comes equipped with a 10,000mAh battery to give up to an additional 36 hours of battery life to your smartphone. Text, chat, and watch videos without worrying about losing your charge as you power devices from one USB-C or two USB-A ports. A 6 in./15cm USB-A to USB-C cable is included, so you can start charging right out of the box.
  • Versatile charging options
    The Belkin BoostCharge features a USB-A to USB-C power cable and three output connectors, including two 4-pin USB Type-A and one 24-pin USB-C, making it capable of simultaneously charging up to 3 devices. This versatility ensures that users can easily charge a wide range of devices, from cellular phones to tablets, without the need for multiple chargers.
  • High capacity battery
    With a 10,000 mAh capacity, this power bank provides ample power to keep devices charged throughout the day. Whether you're at work, traveling, or at home, the Belkin BoostCharge offers the reliability you need to stay connected.
  • Safety and compliance
    Adhering to REACH and RoHS standards, the Belkin BoostCharge not only ensures safety for the user but also demonstrates a commitment to environmental compliance.
Belkin BoostCharge power bank - 2 x USB, 24 pin USB-C - 15 Watt
Power bank
6.5 cm x 10.095 cm x 2.52 cm
Output Connector Type
Total 3: 2 x USB, 24 pin USB-C - on cable: USB-C
DC 5 V
Voltage Provided
DC 5 V
Max Electric Current
2.4 A
10000 mAh
Power Provided
15 Watt
Power Device Details
Power bank: 2 x - 4 pin USB Type A - output - 12 W , Power bank - 24 pin USB-C - input/output - 15 W , Power bank - 5 pin Micro-USB Type B - input
Cables
USB-A to USB-C power cable - 15 cm
Power bank
Tablet, mobile phone
6.5 cm
10.095 cm
2.52 cm
Enclosure Colour
DC 5 V
Input Connectors
5 pin Micro-USB Type B, 24 pin USB-C
Input Connectors Qty
2
Voltage Provided
DC 5 V
Output connectors
Total 3: 2 x 4 pin USB Type A, 24 pin USB-C
Power Provided
15 Watt
Detachable Cable Connector Type
USB-C
2.4 A
Power bank: 2 x 4 pin USB Type A - output - 12 W , Power bank: 24 pin USB-C - input/output - 15 W , Power bank: 5 pin Micro-USB Type B - input
LED indicator, simultaneously charges up to 3 devices
10000 mAh
Equipment Protection Value
2500 US Dollars
RoHS, REACH
