Be Quiet Silent Wings2 8cm Case Fan Fluid Dynamic Bearing Black
Quicklinx: CR8YWS00 Mfr#: BL060
SilentWings 2 fan provides great performance-to-noise ratio and high reliability. It achieves its virtually silent operation without sacrificing airflow, and so offers the perfect balance between superior cooling and serenity as low as 15.8 dB(A).
Its secret: a unique airflow-optimized fan blade design, custom anti-vibration mounts, and a high-tech fluid dynamic bearing with copper core for greatly reduced noise and super-long life.
SilentWings 2 fan is your perfect choice for any application that requires ultimately quiet operation and uncompromised performance.
  • Virtually inaudible
    Advanced fluid dynamic bearing (FDB) with high quality oil avoids mechanical friction. Improved modular vibration damping mounts and rubberized frame help prevent transmission of vibration to computer case and its components.
  • Superior cooling
    Unique airflow-optimized fan blade design maximizes cooling and reduces noise-generating turbulence.
  • Flexible mounting
    Flexible mounting options include screwless installation to case or components as well as mounting with screws.
be quiet! Silent Wings 2 - case fan
Case fan
Package Content
3-pin plug to 4-pin Molex adapter, 5/7/12V fan power adapter
Fan Diameter
80 mm
Fan Height
25 mm
Fan Bearing
Fluid dynamic bearing
Rotation Speed
2000 rpm
Air Flow
26 cfm
Noise Level
14.5 dBA
Power Connector
3-pin plug
Rated Voltage
12 V
Pulse-width modulation (PWM) support
150 g
Anti-vibration
3-year warranty
Case fan
Package Content
150 g
Heatsink & Fan
Fan Diameter
80 mm
Fan Height
25 mm
Fan Bearing
Rotation Speed
2000 rpm
Air Flow
26 cfm
Air Pressure
2.25 mm
Noise Level
14.5 dBA
Power Connector
3-pin plug
Rated Voltage
12 V
Operation Voltage
4 - 14 V
Start Voltage
4 V
Rated Current
0.15 A
Power Consumption
1.8 W
Cable Length
45 cm
Mounting Kit
Included
MTBF
300,000 hour(s)
Anti-vibration
TUV S, RoHS, WEEE
Limited warranty: - 3 years
