Defeat heat created by your processor and allow for improved operation with the A30 by Antec. Designed for compatibility with leading desktop processor sockets, the A30 supports Intel Core i7, and AMD Sempron, among others. This budget-friendly CPU cooler features a whisper-quiet 92 mm LED fan and a large, aluminum heat fin structure with two embedded copper heat pipes, allowing your CPU to cool off efficiently.
Silent LED fan
92mm blue LED fan for ultra-quiet operation. -
Straight touch copper heatpipes
Straight Touch copper heatpipes provide full contact to the CPU and more efficient heat transference. -
Large aluminum fins
43 x 86 mm aluminum fins offer a larger surface area for heat transference. -
Broad socket compatibility
Compatibility with Intel and AMD platforms, and the push-pin mounting system and included thermal paste make for a fast, simple installation.
- Antec A30 - processor cooler
- Product Type
- Processor cooler
- Compatibility
- LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, Socket AM3, LGA1155 Socket, Socket AM3+, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+, LGA1151 Socket
- Heatsink Material
- Aluminium
- Fan Diameter
- 92 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rifle bearing
- Rotation Speed
- 1750 rpm
- Air Flow
- 36 cfm
- Noise Level
- 20 dBA
- Power Connector
- 3-pin plug
- 2 copper heatpipes, blue LED
- 11.6 cm x 12.25 cm x 8.06 cm
- 300 g
- 3-year warranty
- Product Type
- Processor cooler
- 11.6 cm
- 12.25 cm
- 8.06 cm
- 300 g
Heatsink & Fan
- Compatible With
- Heatsink Material
- Aluminium
- Fan Diameter
- 92 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rifle bearing
- Rotation Speed
- 1750 rpm
- Air Flow
- 36 cfm
- Noise Level
- 20 dBA
- Power Connector
- 3-pin plug
- Limited warranty: - 3 years
