With Silent Loop be quiet! brings whisper-silent technology to the world of All-in-One watercooling, making liquid cooling an attractive option for those who want to heavily overclock CPUs for maximum processing performance or cool high-power PC systems.
- be quiet! Silent Loop 240mm - processor liquid cooling system
- Product Type
- Processor liquid cooling system
- Black
- Compatibility
- LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+, LGA2011-3 Socket, LGA1151 Socket
- Heatsink Material
- Copper
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rifle bearing
- Rotation Speed
- 2000 rpm
- Air Flow
- 65.51 cfm
- Noise Level
- 36.9 dBA
- Power Connector
- 4-pin fan connector
- Rated Voltage
- 12 V
- Pulse-width modulation (PWM) support
- 1.349 kg
- 3-year warranty
- Product Type
- 1.349 kg
- Black
Heatsink & Fan
- Compatible With
- Heatsink Material
- Copper
- Heatsink Dimensions
- 277 mm x 124 mm x 30 mm
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rifle bearing
- Rotation Speed
- 2000 rpm
- Air Flow
- 65.51 cfm
- Air Pressure
- 2.23 mm
- Noise Level
- 36.9 dBA
- Power Connector
- Rated Voltage
- 12 V
- Rated Current
- 0.3 A
- Limited warranty: - 3 years
