Be Quiet Pure Wings 2 12cm Case Fan Rifle Bearing - Black
Quicklinx: BGWBWS00 Mfr#: BL046
The Pure Wings 2 family fans are unique in their class, combining outstanding reliability, silent cooling, and a great price-for-performance ratio. It's impressive how much quiet technology the German engineering team has crammed into these fans at this amazing price. They are the ultimate reason to put well-known be quiet! silent cooling in your PC if you haven't already done so.
The Pure Wings 2 120 mm model combines all of the above essential features. It provides maximum cooling airflow and operating noise levels down to a silent 19.2 dB (A). The increased air pressure makes the fans especially recommended for use in water cooling and air cooling setups.
be quiet! Pure Wings 2 - case fan
Case fan
Package Content
4 screws
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
1500 rpm
Air Flow
51.4-87 cfm
Noise Level
19.2 dBA
Power Connector
3-pin plug
Rated Voltage
12 V
12 cm x 12 cm x 2.5 cm
3-year warranty
Case fan
Package Content
4 screws
12 cm
12 cm
2.5 cm
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
1500 rpm
Air Flow
51.4-87 cfm
Air Pressure
1.25 mm
Noise Level
19.2 dBA
Power Connector
3-pin plug
Rated Voltage
12 V
Operation Voltage
5 - 12 V
Start Voltage
5 V
Rated Current
0.09 A
Power Consumption
1.08 W
MTBF
80,000 hour(s)
UL, TUV
Limited warranty: - 3 years
