Dark Rock CPU coolers have long been category leaders, and the significantly upgraded Dark Rock Pro 3 is even more powerful. This virtually inaudible double-tower CPU cooler puts famous be quiet! SilentWings technology in your PC where it really counts. They are excellent for overclocked systems and demanding multi-graphics platforms.
Dark Rock Pro 3 offers top performance-to-noise ratio and the high reliability available. Improved cooling efficiency and really silent operation mean this cooler strikes the perfect balance between cooling and serenity - truly silence and performance without compromises.
- be quiet! Dark Rock PRO 3 - processor cooler
- Product Type
- Processor cooler
- Package Content
- Thermal paste
- Dark nickel
- Compatibility
- Socket 754, Socket 940, LGA775 Socket, Socket 939, LGA1156 Socket, Socket AM2+, LGA1366 Socket, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, LGA1151 Socket
- Heatsink Material
- Aluminium with copper base
- Fan Diameter
- 135 mm/120 mm
- Fan Bearing
- Fluid dynamic bearing
- Rotation Speed
- 1400/1700 rpm
- Air Flow
- 57.2-113.8 cfm
- Power Connector
- 4-pin fan connector
- Rated Voltage
- 12 V
- 7 heatpipes (6mm)
- 13.7 cm x 15 cm x 16.3 cm
- 1.2 kg
- Nickel plated, Silent Wings
- 3-year warranty
- Product Type
- Processor cooler
- Package Content
- Thermal paste
- 13.7 cm
- 15 cm
- 16.3 cm
- 1.2 kg
- Dark nickel
Heatsink & Fan
- Compatible With
- Heatsink Material
- Fan Diameter
- 135 mm/120 mm
- Fan Bearing
- Rotation Speed
- 1400/1700 rpm
- Air Flow
- 57.2-113.8 cfm
- Air Pressure
- 1.23-2.1 mm
- Power Connector
- Rated Voltage
- 12 V
- Power Consumption
- 3.96 W
- 7 heatpipes (6mm)
- RoHS
- Limited warranty: - 3 years
