The AXIS P3354 is a 1-megapixel day and night fixed dome network camera that offers superb video performance. The camera also supports digital pan/tilt/zoom, allowing a view area cropped from the full view to be streamed for viewing or recording. This can be used to minimize the bit rate and storage needs by optimizing the fixed viewing angle after installation, or by allowing pan, tilt and digital zoom in the view.
AXIS P3354 integrates Axis' Lightfinder technology. The outstanding light sensitivity, with maintained colors even in very poor lighting conditions, is obtained by a combination of Axis' expertise in image processing, system-on-chip development and selection of the best optical components. The camera also supports P-Iris control, allowing the camera to precisely control the position of the iris. The iris opening is optimized for depth of field, lens resolution and light inlet, resulting in superb image quality with optimal sharpness.
High performance video
The AXIS P3354 is a 1-megapixel day and night fixed dome network camera that offers superb video performance. It delivers 30 fps in all resolutions up to HDTV 720p/1-megapixel. The camera also supports digital pan/tilt/zoom, allowing a view area cropped from the full view to be streamed for viewing or recording. This can be used to minimize the bit rate and storage needs by optimizing the fixed viewing angle after installation, or by allowing pan, tilt and digital zoom in the view. -
Lightfinder technology and P-Iris control
AXIS P3354 integrates Axis' Lightfinder technology. The outstanding light sensitivity, with maintained colors even in very poor lighting conditions, is obtained by a combination of Axis' expertise in image processing, system-on-chip development and selection of the best optical components. The camera also supports P-Iris control, allowing the camera to precisely control the position of the iris. The iris opening is optimized for depth of field, lens resolution and light inlet, resulting in superb image quality with optimal sharpness. -
Tamper-resistant casing
AXIS P3354 with its tamper-resistant casing is a fixed dome specifically designed for indoor environments where discreet and compact solutions are required. It is the perfect solution for video surveillance in areas such as retail stores, governmental buildings and airports.
- AXIS P3354 6mm - network surveillance camera - dome
- Network surveillance camera - fixed - dome - tamper-proof
- 14.8 cm x 14.8 cm x 9.6 cm
- 430 g
- White
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Optical Zoom
- 2.4 x
- Max Resolution
- 1280 x 960
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Optical Sensor Type
- CMOS - 1/3" - 1.3 MP
- Minimum Illumination
- 0.1 lux - colour - F1.2 , 0.02 lux - B&W - F1.2
- Focal Length Control
- Vari-focal
- Focal Length
- 2.5 mm - 6 mm
- Lens Iris
- F/1.2
- Panning Range (degree)
- 360
- Tilting Range (degree)
- 170
- Ethernet 10Base-T/100Base-TX
- Voltage
- PoE
- Motion sensor, Backlight Compensation (BLC), sharpness control, white balance, colour control, progressive scanning, brightness control, Power over Ethernet, contrast control, image mirror, Wide Dynamic Range (WDR), SDHC-card slot, ONVIF support, infrared cut filter, Privacy Mask Function, P-Iris control, text stamp, Video Motion Detection Technology, tamper-detection, Lightfinder technology, digital PTZ function
- 3-year warranty
- Environmental Parameters (operating)
- 0 °C - 50 °C; 10 - 85% (non-condensing) relative humidity
- Form Factor
- Dome
- Wired
- 14.8 cm
- 14.8 cm
- 9.6 cm
- 430 g
Camera
- Colour - Day&Night - fixed - tamper-proof
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 1280 x 960
- Motion Detection
- Exposure Range
- 2 sec - 1/29500 sec
- Frame Rate (max)
- RAM
- 256 MB
- Flash Memory
- 128 MB
Image Sensor
- 1.3 MP CMOS 1/3"
Lens Construction
- Vari-focal
- Optical Zoom
- 2.4 x
- Focal Length
- 2.5 mm - 6 mm
- Lens Iris
- F/1.2
- Horizontal Field of View (degree)
- 49 - 105
Panning
- Range (degree)
- 360
Tilting
- Range (degree)
- 170
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, IGMP, SSL, QOS
- Supported Memory Cards
- SD Memory Card, SDHC Memory Card
- Included Accessories
- Smoked dome cover
- C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 61000-6-2, IEC 60950-1, EN 60950-1, IEC 60068-2-27, IEC 60068-2-64, IEC 60068-2-1, IEC 60068-2-2, IEC 60068-2-14, IEC 60068-2-78
- White
- Power Requirements
- PoE
- Software Included
- Drivers & Utilities
- Limited warranty - 3 years
- 0 °C
- 50 °C
- Relative Humidity (operating)
- 10 - 85% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
