Axis M1113 Network Camera
Quicklinx: 78YCWS00 Mfr#: 0340-001
AXIS M1113 network camera with CS-mount, varifocal, DC-iris lens provides excellent image quality without motion blur using progressive scan at 30 frames per second in SVGA resolution. The cost-effective, compactly designed camera offers multiple H.264 and Motion JPEG streams that can be individually optimized for bandwidth and storage efficiency. It features Power over Ethernet, digital PTZ and a pixel counter to verify that the required pixel resolution is met. Intelligent video functionalities include video motion detection and active tampering alarm. AXIS M1113 is ideal for securing stores, malls, schools, banks and other office buildings, indoors as well as in an outdoor housing.
  • Excellent image quality with progressive scan
    The AXIS M1113 with CS-mount, varifocal, DC-iris lens provides excellent image quality without motion blur using progressive scan at 30 frames per second in SVGA resolution. Multiple H.264 streams, as well as motion JPEG streams, can be provided either in full frame rate or individually optimized for different quality needs and bandwidth constraints.
  • Power over Ethernet
    Power over Ethernet supplies power to the camera via the network, eliminating the need for power cables and reducing installation costs. The pixel counter further helps the installer verify that the pixel resolution of an object or face fulfills regulatory or specific customer requirements, for example, for facial identification purposes.
  • Digital pan/tilt/zoom
    The AXIS M1113 supports digital pan/tilt/zoom, which allows a view cropped from the full view to be streamed for viewing or recording.
AXIS M1113 Network Camera - network surveillance camera
Network surveillance camera - fixed
6.1 cm x 9.4 cm x 4.3 cm
200 g
Wired
Camera
Optical Zoom
2.8 x
Max Resolution
800 x 600
Optical Sensor Type
CMOS - 1/4"
Minimum Illumination
0.6 lux F1.4
Focal Length Control
Vari-focal
Focal Length
2.9 mm - 8.2 mm
Lens Mounting
CS-mount
Lens Iris
Auto iris (DC)
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Backlight Compensation (BLC), sharpness control, digital image rotation, white balance, colour control, progressive scanning, brightness control, contrast control
1-year warranty
Environmental Parameters (operating)
-20 °C - 50 °C; 20 - 80% relative humidity
Wired
6.1 cm
9.4 cm
4.3 cm
200 g
Camera
Colour - fixed
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
800 x 600
Exposure Range
1/24500 sec - 1/6 sec
0.6 lux F1.4
Video Capture
800 x 600 @ 30 fps
RAM
128 MB
Flash Memory
128 MB
Image Sensor
CMOS 1/4"
Lens Construction
CS-mount - vari-focal
Optical Zoom
2.8 x
Focal Length
2.9 mm - 8.2 mm
Lens Iris
Auto iris (DC)
Horizontal Field of View (degree)
25 - 65
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, Bonjour, RTCP, IGMP
Interfaces Details
1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45
Stand
C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 60950-1, EN 61000-6-3
Power Requirements
PoE
Software Included
Drivers & Utilities
Limited warranty - 1 year
-20 °C
50 °C
Relative Humidity (operating)
20 - 80%
