AVerMedia SPB350+ Visualiser
Quicklinx: 894MWS00 Mfr#: 61P0C9P000AW
The AVerVision SPB350+ is a high quality, yet affordable, platform visualize designed for budget conscious users who still require abundant features and functions. Featuring 30fps full motion high definition 1080p video output, users are able to take advantage of the clarity of HD monitors and projectors. Images can be captured to the document camera itself, an SD card, or directly to a PC or MAC. The built-in 4"x 5" lightbox allows for the display of slides, negatives, or other transparent documents. The AVerVision SPB350+ is the perfect high-value visualize solution for virtually any display application.
AVer AVerVision SPB350+ - digital document camera
Digital document camera
47.8 cm x 38.1 cm x 50.5 cm
5.6 kg
Wired
Camera
Colour - 650 TVL
Optical Zoom
12 x
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Optical Sensor Type
CMOS - 1/2.5" - 5 MP
Focal Length
6 mm - 60 mm
Focus Adjustment
Automatic, manual
Lens Iris
F/3.5
USB, S-Video, composite video, VGA, DVI
Manual white balance, picture-in-picture capability, digital image freeze, SD-card slot, built-in LED lights, auto white balance
5-year warranty
Wired
47.8 cm
38.1 cm
50.5 cm
5.6 kg
Camera
Horizontal Resolution (TV Lines)
650
Max Digital Video Resolution
1920 x 1080
Digital Zoom
8
Frame Rate (max)
Still Image Capture Resolution
1920 x 1080
Image Sensor
5 MP CMOS 1/2.5"
Lens Construction
Optical Zoom
12 x
Focal Length
6 mm - 60 mm
Lens Iris
F/3.5
Focus Adjustment
Automatic, manual
Video
Computer Interface
USB
1 x display / video - composite video/S-video output , 1 x display / video - VGA output - 15 pin HD D-Sub (HD-15) , 2 x display / video - VGA input - 15 pin HD D-Sub (HD-15) , 1 x USB , 1 x display / video - composite video output - RCA , 1 x display / video - DVI-Analog/Digital , 1 x network - RS-232
Remote control, dust cover
Software Included
AVer+ Software
Limited warranty - 5 years
