AVerMedia M70 Visualiser
Quicklinx: 894JWS00 Mfr#: 61P0H3P000AC
At 192x, the M70 packs one of the biggest zooms you will find in a document camera. With this level of magnification, you can actually see chemical reactions at work, including yeast converting sugar water into energy and carbon dioxide. It looks like networks of gears and cogs in motion. A bonus is that when you are in digital zoom, you can move around the image while you are still zoomed in.
  • Megapixels, mega images, mega wows
    Learning becomes wonderment when it's unfolding on the big screen and nothing puts on a show like the 5 megapixels of the M70 doc cam that's primed to show crisp text, bright images and vivid colors. The M70 is also engineered with a large imaging sensor to collect lots of light. More megapixels and more light mean better resolution and gorgeous detail for showcasing your classroom's best.
  • See micro worlds in action
    With the M70's optional microscope adaptor, you can explore nature's tiniest communities in action. Simply fit the adapter to any standard microscope eye-piece and you can now display small worlds on big screens.
  • If only everything was 30 fps smooth
    AVer Information suffers a little from attention deficit, so AVer Information made sure that the M70 shows only 30 fps video. That means it displays only smooth movement and images without any bumps, lags or freezes. Even math demonstrations are more captivating.
  • Shed some light
    Usually when the projector is on, the lights are off. Since the M70 is connected to a projector, it has built-in LED lights in the camera head to illuminate and display the objects underneath beautifully.
  • Make a point
    Need to explain a tricky concept or emphasize a key point? By simply plugging in an USB mouse into the M70, you can easily add annotations, highlights, arrows and captions. You don't need a computer.
AVer AVerVision M70 - digital document camera
Digital document camera
Audio
Yes: built-in microphone
18.2 cm x 45.2 cm x 50.4 cm
2.1 kg
Wired
Camera
Colour - NTSC
Optical Zoom
12 x
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Optical Sensor Type
CMOS - 1/3.2" - 5 MP
Focus Adjustment
Automatic, manual
USB, composite video, RGB, HDMI
1 - USB cable - external , 1 - video / serial cable - external , 1 - VGA cable - external
Audio recording, picture-in-picture capability, digital image rotation, digital image freeze, adjustable self timer, image mirror, built-in LED lights, SDHC-card slot, negative conversion, image split, built-in USB plug, video recording, Auto Zone Focus
Microsoft Certification
Compatible with Windows 7
Audio Support
Wired
18.2 cm
45.2 cm
50.4 cm
2.1 kg
Camera
Video Format
NTSC
Max Digital Video Resolution
1920 x 1080
Digital Zoom
16
Frame Rate (max)
Still Image Capture Resolution
1280 x 720, 1600 x 1200, 1024 x 768, 1280 x 1024, 1920 x 1080
Image Sensor
5 MP CMOS 1/3.2"
Lens Construction
Optical Zoom
12 x
Focus Adjustment
Automatic, manual
Video
Composite video, RGB, HDMI
Computer Interface
USB
1 x microphone - input - mini-phone 3.5 mm , 1 x audio / video - HDMI output - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A , 1 x USB , 1 x audio - output - mini-phone stereo 3.5 mm , 1 x display / video - VGA input - 15 pin HD D-Sub (HD-15) , 1 x display / video - VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial / video - RS-232/composite video output , 1 x video - composite video output - RCA
Carrying case, remote control, anti-glare sheet
1 x USB cable - external , 1 x video / serial cable - external , 1 x VGA cable - external
FCC, RoHS
Power adapter - external AC 120/230 V (50/60 Hz)
Software Included
Drivers & Utilities, AVer+ Software
Microsoft Windows XP SP2, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple MacOS X Lion 10.7
