Aten 2-Port USB KVMP Switch
Quicklinx: 917MWS00 Mfr#: CS102U
Control two PC's or Servers with one USB, Keyboard, Monitor and Mouse using the Hawking CS102U KVM Switch. This kit includes everything you need to connect two PCs or Servers, one Keyboard, one Monitor and one Mouse together to the CS102U Switch. Installation is effortless. There is no software to configure, no repetitive installation routines and compatibility issues are non-existent. It works with most hardware platforms and with most operating systems.
The CS102U saves space and money by reducing the number of peripherals and accessories needed in your work environment. It also eliminates the inconvenience of having to move between 2 computers. The CS102U is the perfect solution for Small Office and Home Office environments needing cost effective ways to control multiple PCs.
KVM Switch - KVM switch - 2 ports
Subtype
KVM
Ports
2 x KVM port(s)
KVM Users Qty
1 local user
(50/60 Hz)
Grey
Microsoft Windows 98, Apple MacOS 8.6 or later, Microsoft Windows 2000 / NT4.0
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
1 x USB Type A , 1 x VGA HD-15 , 1 x USB Type B , 1 x VGA HD-15
External power adapter
(50/60 Hz)
Grey
2 x USB cable
Limited warranty - parts and labour - 2 years
