The CubiQ CS1764A USB 2.0 DVI KVMP switch charts a revolutionary direction in KVM (Keyboard, Video, Mouse) switch functionality by combining a 4 port KVM switch with a 2 port USB 2.0 hub at the same time as it provides an interface for a digital monitor (DVI). In addition, the CS1764A comes with ATEN's Video DynaSync technology, which optimizes display resolution, and power on detection, which means if one computer is powered off, the CS1764A will automatically switch to the next powered-on computer.
As a KVM switch, it allows users to access four computers from a single USB keyboard, USB mouse, and monitor console. As a USB 2.0 hub, it permits each computer to access any peripherals connected to the hub on a 'one computer at a time' basis.
- ATEN CubiQ CS1764A - KVM / audio switch - 4 ports
- Subtype
- KVM
- Ports
- 4 x KVM / audio
- KVM Users Qty
- 1 local user
- Firmware upgradable, HDCP compliant, Video DynaSync
- 27 cm x 8.7 cm x 5.5 cm
- 0.94 kg
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 4 x KVM / audio
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 1920 x 1080 @ 60 Hz
- Built-in Devices
- USB Hub
- 4 x DVI-I , 4 x USB 2.0 Type B , 4 x audio mini-jack , 4 x microphone mini-jack , 1 x DVI-I , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 2 x audio mini-jack , 2 x microphone mini-jack , 1 x USB 2.0 Type A
- Power Device
- External power adapter
- 10 Watt
- DDC-2B
- 27 cm
- 8.7 cm
- 5.5 cm
- 0.94 kg
- 0 °C
- 50 °C
- 0 - 80%
