Asus ZenBook Pro Duo UX582LR Core i9 32GB 1TB 15.6" UHD RTX 3070
Quicklinx: GKK2WS00 Mfr#: UX582LR-H2014T
  • IEEE 802.11n
Take your creativity and productivity to the next level with the groundbreaking ASUS ZenBook Pro Duo! Designed to give you the ultimate edge in workflow efficiency, the unique design features a full-width 4K ASUS ScreenPad Plus that works seamlessly with the main 4K UHD OLED display. It's never been this easy to harness your full creative power.
  • ScreenPad Plus
    ASUS ScreenPad Plus gives you on-the-go computing like you've never experienced before. It's a full-width 4K secondary touchscreen that works seamlessly with the main 15.6-inch 4K UHD OLED touchscreen, giving you endless ways to optimize and personalize your workflow. You can drag apps or in-app toolbars onto ScreenPad Plus to give you more room to work on the main display, wherever you are.
  • Perfect ergonomics, for stylus or keyboard
    With ZenBook Pro Duo you can really let your creativity flow. Both multi-touch displays support stylus input, but ScreenPad Plus gives you a superbly ergonomic and stable platform for writing or drawing. Take notes, sketch out your ideas, or do precision graphical editing.
  • Unrivaled portable power
    ZenBook Pro Duo is powered by an advanced processor, gaming-grade graphics and blisteringly fast storage. This ultrapowerful combination ensures that ZenBook Pro Duo takes professional-quality tasks in its stride, such as multi-layer photo or video editing, 3D graphics rendering or even game live-streaming.
  • Ultrapowerful computing
    ZenBook Pro Duo is incredibly powerful, featuring fast processor that's designed to deliver the ultimate multitasking performance. With its unprecedented frequency, ZenBook Pro Duo can effortlessly handle all the apps on your main screen and ScreenPad Plus, for fluid cross-screen workflow.
  • Professional-grade graphics
    For the perfect graphics experience, ZenBook Pro Duo uses ultrapowerful GPU that enables you to enjoy the power of real-time ray tracing and high-resolution video editing for the ultimate visual realism. With ZenBook Pro Duo, your creativity will know no bounds.
  • 4K UHD OLED, ultraslim bezels
    The 4K UHD OLED display on ZenBook Pro Duo is truly amazing, with a four-sided frameless design featuring ultraslim bezels. The brilliant OLED touchscreen delivers ultra-vivid colors and deep blacks, with a cinema-grade 97% DCI-P3 color gamut making it a superb all-rounder for professional work and entertainment. The barely-there bezels increase the screen-to-body ratio, giving you more screen, and less distraction!
  • Extraordinary color
    To display incredibly accurate, vivid, and realistic colors, ZenBook Pro Duo's display has Pantone Validated color accuracy and supports an exceptionally wide 97% DCI-P3 color gamut. The DCI-P3 color space - widely used in the motion picture industry - is increasingly the preferred choice of creative professionals for its increased range of possible colors, and makes images on ZenBook Pro Duo look simply stunning.
  • Ultimate numeric keypad solution
    ZenBook Pro Duo features ASUS NumberPad, an LED-illuminated numeric keypad integrated into the touchpad. Tap on the top-right NumberPad icon for one second to switch the function on and off, and tap on the top-left icon to choose one of two brightness levels. Even when the NumberPad is activated, the touchpad can be used for cursor control thanks to its intelligent software.
  • Hands-free login with face unlock
    Enjoy hands-free login on your laptop, using the infrared camera with Windows Hello to login with just a glance - even in the dark!
  • Ultrafast connectivity
    ZenBook Pro Duo is built for creative professionals, so there's no compromise on connectivity. A full set of high-performance I/O ports - including Thunderbolt 3 and USB-C - give you dongle-free connectivity whatever you're doing, wherever you are. Wi-Fi 6 (802.11ax) takes wireless speeds to the next level, for super-smooth connections to the world.
  • Audio tuned by Harman Kardon
    The ASUS Golden Ear team worked with renowned home and automotive audio experts Harman Kardon to ensure the perfect audio experience. A tailored mix of superior hardware - including smart amplifier technology that delivers louder sound with no distortion - gives you sound like no other laptop.
  • Military-grade toughness and build quality
    ZenBook Pro Duo meets the ultra-demanding MIL-STD 810G military standard for reliability and durability, undergoing a punishing test regime that includes extended tests for operation in harsh environments including extreme altitudes, temperatures and humidity. It has also passed ASUS internal laptop tests that far exceed the standards set by the industry.
ASUS ZenBook Pro Duo UX582LR H2014T - 15.6" - Intel Core i9 - 10980HK - 32 GB RAM - 1 TB SSD
Notebook
Operating System
Windows 10 Home
Intel Core i9 (10th Gen) - 10980HK / 2.4 GHz, up to 5.3 GHz / 16 MB Cache
32 GB DDR4 (provided memory is soldered)
Storage
1 TB SSD - NVMe
Display
15.6" OLED touchscreen 3840 x 2160 / Ultra HD 4K
Graphics
NVIDIA GeForce RTX 3070 / Intel UHD Graphics
Video Memory
8 GB GDDR6 SDRAM
Input Device
Stylus, NumberPad, ScreenPad Plus
Keyboard Backlight
Integrated Webcam
Bluetooth 5.0, 802.11a/b/g/n/ac/ax
8-cell
Security
Trusted Platform Module (TPM) Security Chip
Celestial blue
35.98 cm x 24.92 cm x 2.15 cm
2.34 kg
Repairability Index
6.1 (out of 10)
Notebook
Operating System
Windows 10 Home
Processor / Chipset
CPU
Intel Core i9 (10th Gen) 10980HK / 2.4 GHz
Max Turbo Speed
5.3 GHz
Number of Cores
8-core
Cache
16 MB
Chipset
Intel HM470
Intel Smart Cache, Intel Turbo Boost Max Technology 3.0
RAM
32 GB (provided memory is soldered)
DDR4 SDRAM
Storage
Main Storage
1 TB SSD M.2 PCIe 3.0 - NVM Express (NVMe)
Display
15.6" OLED
Touchscreen
Resolution
3840 x 2160 (Ultra HD 4K)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
440 cd/m²
Colour Gamut
100% DCI-P3
Glossy, ASUS Splendid Video Intelligence Technology, Pantone Validated
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
8 GB GDDR6 SDRAM
Camera
Yes - HD
Camera Features
IR camera, Windows Hello
Sound
Harman/kardon stereo speakers, array microphone
Input
Keyboard, stylus, NumberPad, ScreenPad Plus
Keyboard Backlight
Chiclet keyboard, 14" 4K UHD (3840 x 1100) touch display
Communications
Wireless
Dual stream (2x2)
8-cell Lithium Ion
92 Wh
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
240 Watt, 20 V, 12 A
Connections & Expansion
Interfaces Details
Headphone/microphone combo jack , USB 3.2 Gen 2 , 2 x Thunderbolt 3 (supports DisplayPort) , HDMI
Celestial blue
Case Material
Aluminum
Security
MIL-STD-810G tested
Stylus, power adapter, sleeve, stand, palm rest
2.34 kg
Sustainability Information
Repairability Index
6.1 (out of 10)
TCO Certified
