Make your own motion-sensing software, only with the ASUS Xtion PRO! The world's first and only professional PC motion- sensing software development kit features OPNI NITE SDK middleware compatibility, making development a cinch. Create games, applications or whatever your creativity muscles can muster! Once you're done with the masterpiece, you can even sell it on the upcoming ASUS@vibe online entertainment content store and make some money!
Worldwide exclusivity
It is the world's first and exclusive professional PC motion sensing development solution. You can make your fantastic ideas come true and introduce a better future to the public. -
Especially designed for developers to create various applications
The Xtion PRO development solution allows developers to apply the motion-sensing technology in various applications and industries to stand out from the competition. For example: Electronic Kanban is an ideal application for this technology and can be used widely for marketing, guidance or tourism and so on. Physical rehabilitation is also a good field for body detection applications. There are a number of fields that could benefit from motion-based technology, such as education, medical, conferences, games and many more. -
Two function systems to make development easy
Xtion PRO uses Infrared sensor and adaptive depth detection technology to capture users' real-time body movements, making body tracking more precise. The Xtion PRO development solution comes with a set of developer tools to make it easier for developers to create their own gesture-based applications without the need to write complex programming algorithms. -
Easy to use
The Xtion PRO features an easy plug and play USB design, with the Xtion PRO development solution OPNI NITE middleware compatible.
- Asus Xtion PRO - motion sensor - wired
- Product Type
- Motion sensor
- Connectivity Technology
- Wired
- Video conferencing, OpenNI
- Product Type
- Motion sensor
- Wired
- Interface
- USB
- 1 x USB 2.0
- OS Required
- Linux, Microsoft Windows Vista (32/64 bits), Linux (64-bit), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Ubuntu 10.10
- Included Accessories
- USB cable (1.7 m)
- 17.8 cm
- 3.8 cm
- 4.8 cm
