Asus ROG Cetra True Wireless Earphones
Quicklinx: GRXZWS00 Mfr#: 90YH03G1-B5UA00
Type: Earbuds
£74.99 ex VAT
£89.98 inc VAT
  • Stay In-Sync, stay immersed
    ROG Cetra True Wireless gaming headphones are equipped with hybrid ANC technology and low-latency wireless to keep you in the zone and in sync with immersive audio experiences. EQs and specially tuned 10 mm ASUS Essence drivers add another layer of quality to your gaming audio, and more hours of battery life, wireless charging and IPX4 water resistance let you keep gaming wherever you go.
  • Low-latency wireless audio
    Gaming mode can be activated with a simple touch or via Armory Crate, enabling low-latency connection and greater synchronization between audio and video playback for competitive gaming.
  • Active Noise Cancelation for full immersion
    Hybrid Active Noise Cancelation (ANC) detects and filters out noise coming from both inside and outside of the headphones, enabling an immersive audio experience that leaves you undisturbed when you're jamming to your favorite beats or taking on missions in your favorite game.
  • Exceptional audio
    Specially tuned 10 mm ASUS Essence drivers and airtight chambers provide rich, clean sound, particularly in the mid and high frequency range, while powerful bass lets you enjoy true-to-life audio.
  • Extensive battery life with fast charging
    With ANC off, you can enjoy several hours of use on a single charge and extend that by extra hours with the charging case. When you're in a jam, just 10 minutes of charging gives you several hours of usage thanks to quick-charge technology.
  • Water resistance
    IPX4 splash-proof water resistance adds protection and extra durability.
  • Instant control at your fingertips
    Simple quick-touch controls at the tips of your fingers enable rapid in-game adjustments.
ASUS ROG Cetra True Wireless - true wireless earphones with mic
True wireless earphones - Bluetooth
Recommended Use
Game console, portable electronics, computer
Gaming
Style
Games
Headphones Form Factor
In-ear
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Sound Effects
7.1 Channel Virtual Surround Sound
Audio Specifications
Frequency Response 20 - 20000 Hz
Impedance
32 Ohm
Active Noise Canceling
Microphone Operation Mode
Omni-directional
Controls
Play/pause, next/previous track, voice assistant, ANC on/off, game mode on/off, ANC mode
True wireless earphones - Bluetooth - wireless
Style
Games
Dimensions & Weight Details
Charging case: 42 g , Earphone: 5 g
Recommended Use
Gaming
Touch control
Protection
Splashproof, IPX4
Audio Output
In-ear
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Sound Effects
Active Noise Cancelling Technology
Hybrid ANC
Frequency Response
20 - 20000 Hz
Impedance
32 Ohm
Diaphragm
10 mm
Magnet Material
Neodymium
Microphone
Built-in
Omni-directional
Sensitivity
-38 dB
Frequency Response
100 - 10000 Hz
Remote Control
Controls
2 pairs of ear tips
Cable Details
Charging cable - 60 cm
IPX4
Headphone battery rechargeable - wireless charging
Run Time (Up To)
5.5 hour(s)
Run Time Details
Continuous playback (noise cancelling ON): up to 4.8 hours , Continuous playback (noise cancelling OFF): up to 5.5 hours , Continuous playback (noise cancelling OFF / with included charging case): up to 27 hours , Continuous playback (noise cancelling ON / with included charging case): up to 21.8 hours
Type: Earbuds
Brand: Asus
