Asus Xonar Xense PCI-E  Gamer Headphone Amp Soundcard Optimized for bundled Sennheiser PC350 Headset
Quicklinx: 74W5WS00 Mfr#: XONAR XENSE
ASUS and Sennheiser Deliver World's First Total Audio Solution Optimized for First Person Shooters - Xonar Xense
The new ASUS Xonar Xense One and Sennheiser PC 350 Xense Edition package is the result of cooperation between ASUS and premier personal audio maker, Sennheiser. Xonar Xense is a perfectly matched combination of cutting edge audio card and superior quality headphones that reinvents immersive sound for serious gamers. The gaming audio set creates unbeatable sonic experiences in PC gaming that are sure to be appreciated by hardcore gamers keen on competitive online play.
Triumph over your opponents in FPS games with precision acoustics
Designed as a whole is the best way to get ultimate audio performance
Xonar Xense
Powerful headphone amplifier and matched high-impedance driver secure FPS-optimized sound positioning and dynamics
Xonar Xense1
Embrace clarity for the win with EMI shields and 118dB SNR
No footsteps missed in front of the 118dB SNR sound clarity brought by EMI shield and studio-standard 6.3mm audio jack
Xonar Xense2
Stylish full-stainless steel design matches the earcup cover of Sennheiser headset
Xonar Xense2
Fight to the end with the ergonomic headset
Pro gamers' long-hour usage catered by excellent headset ergonomics
Xonar Xense2
New Gain Level perfectly tuned up for the headset
To ensure the supreme performance of Sennheiser PC 350 Xense Edition, ASUS and Sennheiser engineers co-worked and tuned up a new Gain Level perfect for Sennheiser PC 350 Xense Edition sound performance.
Xonar Xense2
Cable length 3m (9.8 feet)
Connector plugs 2 x 6.3mm
Speaker type Dynamic, 38mm, Nd magnet
Frequency response 10 - 26,000Hz
Impedance 150?
Distortion less than 0.1%
Microphone
Frequency response 50 - 16,000Hz
Pick-up pattern Noise canceling
Sensitivity -38dBV at 94dBSPL
Output Signal-to-Noise Ratio (A-Weighted)
118 dB
Input Signal-to-Noise Ratio (A-Weighted)
118 dB
Output THD+N at 1kHz
0.00039% (-108dB) for Front channel of Line-out
Input THD+N at 1kHz
0.0003% (-110dB) for Line-in
Frequency Response (-3dB, 24-bit/96kHz input)
<10Hz to 46KHz
Output/Input Full-Scale Voltage
2 Vrms (5.65 Vp-p)
PCI Express
PCI Express Rev.1.0a specification compatible, Maximum full 2.5Gbps bandwidth per direction and optimized latency for high-definition audio processing, Compatible with X1, X4, X8, X1 6 PCI Express slots
Audio Processor
ASUS AV100 High-Definition Sound Processor (Max. 192kHz/24bit)
24-bit D-A Converter of Digital Sources
Texas Instruments PCM1796*1 for Front-Out (123dB SNR, Max. 192kHz/24bit); Cirrus-Logic CS4362A*1 for other 6 channels (114dB SNR, Max.192kHz/24bit)
24-bit A-D Converter for Analog Inputs
Cirrus-Logic CS5381 x 1 (120dB SNR, Max. 192kHz/24bit)
High Fidelity Headphone Amplifier
Texas Instruments 6120A2*1 (120dB SNR, -117dB THD+N @ Vcc+-12V, RL=600O, f=1kHz)
Analog Playback Sample Rate and Resolution
44.1K/48K/96K/192KHz @ 16/24bit
Analog Recording Sample Rate and Resolution
S/PDIF Digital Output
44.1K/48K/96K/192KHz @ 16/24bit, Dolby Digital
ASIO 2.0 Driver Support
44.1K/48K/96K/192KHz @16/24bit with very low latency
Analog Output Jack
6.30mm jack*1 (Headphone out); 7.1ch analog output (via bundled audio splitter cable)
Analog Input Jack
6.30mm jack *1 (Shared by Line-In/Mic-In)
Other line-level analog input (for CD-IN/TV Tuner)
Aux-In (4-pin header on the card)
Digital S/PDIF Output
High-bandwidth Coaxial/TOS-Link combo port supports 192KHz/24bit
Front-Panel Header
Shared by Headphone out / 2 channels out / Microphone in
Operation System
Windows 7/Vista/XP/MCE2005
Dolby® Technologies
Dolby® Digital Live, Dolby® Headphone, Dolby® Virtual Speaker, Dolby® Pro-Logic II
Smart Volume Normalizer™
Normalizes the volume of all audio sources into a constant level and also enhances your 3D sound listening range and advantages in gaming
Xear 3D™ Virtual Speaker Shifter
Virtual 7.1 speaker positioning
FlexBass™
Professional Bass Management/Enhancement system
Other Effects
10-band Equalizer/27 Environment Effects
3D Sound Engines/APIs
DirectSound3D® GX 2.0 & 1.0, EAX®2.0&1.0, DirectSound® HW, DirectSound SW, OpenAL generic modes, 128 3D sounds processing capability
DS3D GX2.5
GX 2.5 supports EAX gaming sound effects and Di rectSound 3D hardware enhanced functions for more games on Windows XP/Vista/7. (DirectX/DirectSound 3D compatible)
Accessories
1 x S/PDIF optical adaptors, 1 x 6.3mm to 3.5mm stereo adapter, 1 x 7.1 channel audio splitter cable, 1 x Driver CD,1 x Quick Start Guide
Size
111.15mm x 178.06mm
