Asus Xonar DGX 5.1 Sound Card
Quicklinx: CH5DWS00 Mfr#: 90-YAA0Q1-0UAN0BZ
The Xonar DGX audio card combines Dolby Headphone 5.1 high definition surround with the ASUS-exclusive GX 2.5 gaming audio engine and an on-board headphone amplifier. These result in accurate and deep audio that brings every nuance and sound across fully, making the Xonar DGX 5.1 an ideal audio card for gamers who want to remain totally aware of their play environments.
  • Optimized for immersive gaming action through precision audio
  • 3 headphone amp gain modes for different usage scenarios
    The Xonar DGX uses three modes to cater to different usage scenarios: voice, pro-gaming, and exciter modes. Sound positioning helps gamers become better informed of environments and thus more competitive, especially in multiplayer first person shooters.
  • Dolby Headphone technology for an immersive 5.1-channel surround experience
    The Xonar DGX 5.1 uses Dolby Headphone technology to level up your stereo headphones to surround sound brilliance.
  • GX 2.5 for realistic 3D gaming audio effects
    The exclusive ASUS GX 2.5 gaming audio engine on the Xonar DGX 5.1 allows up to 128 different sound effects simultaneously for a realistic 3D audio environment.
  • Automatic jack-sensing front-panel output
    The Intel HDA-compatible front-panel header automatically switches output between the back and the front of the case once speakers/headphones are plugged in. Never again will you be bothered by the need to change connection settings manually!
ASUS Xonar DGX - sound card
Sound card - low profile
Enclosure Type
Internal
Interface Type
PCI Express
17.04 cm x 6.44 cm
Signal Processor
CMI-8786
Sound Output Mode
5.1 channel surround
DAC Resolution
24-bit
Sample Rate
44.1 kHz (min) - 96 kHz (max)
Signal-To-Noise Ratio
105 dB
Hardware Controls And Indicators
10 band EQ
Internal
Interface Type
PCI Express
17.04 cm
6.44 cm
Processor / Memory
Signal Processor
CMI-8786
Audio Output
Sound Output Mode
DAC Resolution
24-bit
Sample Rate
105 dB
Frequency Response
10 - 48000 Hz
10 band EQ
Headphone Amplifier, Smart Volume Normalizer, Magic Voice, FlexBass
Dolby Headphone, DirectSound3D GX 2.5
3 x audio line-out - mini-phone 3.5 mm , 1 x audio line-in/microphone - mini-phone 3.5 mm , 2 x audio line-in - 4 pin MPC , 1 x SPDIF output - TOSLINK
Low-profile bracket
Software
Drivers & Utilities, C-Media Xear 3D
