Built-in headphone AMP
Powers up every sound detail in gaming. 3 headphone AMP gain modes is designed for different usage scenarios. -
Automatic jack-sensing front-panel output
Audio auto-switched from back to front with headphone plugged in!
- Output Signal-to-Noise Ratio (A-Weighted):
- 105 dB
- Input Signal-to-Noise Ratio (A-Weighted):
- 103 dB
- Output THD+N at 1kHz:
- 0.0025% (-92dB)
- Input THD+N at 1kHz:
- 0.0022% (-93dB)
- Frequency Response (-3dB, 24-bit/96kHz input):
- <10Hz to 48kHz
- Output/Input Full-Scale Voltage
- 1Vrms (3Vp-p)
- PCI Bus Compatibility
- PCI v2.2 or above bus compatible
- Audio Processor:
- C-Media CMI8786 High-Definition Sound Processor (Max. 96KHz/24bit)
- 24-bit D-A Converter of Digital Sources:
- Cirrus Logic CS4245*1 (104dB DNR, Max. 192KHz/24bit) / Cirrus Logic CS4361*1 (103dB DNR, Max. 192KHz/24bit)
- 24-bit A-D Converter for Analog Inputs:
- High Fidelity Headphone Amplifier:
- Optimized for 32~150O
- Analog Playback Sample Rate and Resolution:
- 44.1K/48K/96KHz @ 16/24bit for all channels
- Analog Recording Sample Rate and Resolution:
- S/PDIF Digital Output:
- 44.1K/48K/96KHz @ 16/24bit, Dolby Digital, DTS, WMA-Pro
- ASIO 2.0 Driver Support:
- Analog Output Jack:
- 3.50mm mini jack *3 (Front/Side/Center-Subwoofer)
- Analog Input Jack:
- 3.50mm mini jack *1 (Line-In/Mic-In)
- Other line-level analog input (for CD-IN/TV Tuner):
- Aux-In (4-pin header on the card)
- Digital S/PDIF Output:
- High-bandwidth Optical Connector supports 96KHz/24bit - additional SPDIF-out header for HDMI audio output
- Front-Panel Header:
- Supports headphone jack-detection, automatically switch audio output from back-panel to front
- Operation System:
- Windows 7/Vista/XP/MCE2005
- Dolby® Technologies:
- Dolby Headphone: technology allows users to listen to music, watch movies, or play games with the dramatic 5.1-channel surround or realistic 3D spacious effects through any set of stereo headphones.
- Smart Volume Normalizer™:
- Normalizes the volume of all audio sources into a constant level and also enhances your 3D sound listening range and advantages in gaming
- Xear 3D™ Virtual Speaker Shifter:
- Adjustable virtual 7.1-speaker positioning
- Magic Voice™:
- Changes your voice pitch to different types (Monster/Cartoon…) for disguising your real voice or just for fun in online chatting
- Karaoke Functions:
- Music Pitch-Shifting, Vocal Cancellation, and Microphone Echo effects with Stereo Mix recording (Wave and Mic-in) for online Karaoke or online DJ applications
- FlexBass™:
- Professional Bass Management/Enhancement system
- Other Effects:
- 10-band Equalier/27 Environment Effects
- 3D Sound Engines/APIs - Windows 7
- DirectSound3D® GX 2.5, EAX®2.0&1.0, DirectSound® HW, DirectSound SW, A3D®1.0, OpenAL generic modes, 128 3D sounds processing capability
- 3D Sound Engines/APIs - Windows Vista
- 3D Sound Engines/APIs - Windows XP
- DS3D GX2.5:
- DS3D GX 2.5 supports EAX gaming sound effects and DirectSound 3D hardware enhanced functions on Windows 7/Vista. (DirectX/DirectSound 3D compatible)
- Accessories
- 1 x Low-Profile Bracket, 1 x Driver CD, 1 x QuickStart Guide
- Size (W x H)
- 64.39 x 170.44mm
