Asus VZ27AQ 27" 2560x1440 IPS Monitor
Quicklinx: CXNHWS00 Mfr#: VZ27AQ
ASUS VZ27AQ has a space-saving design with an ultra-slim profile. Its frameless design makes it perfect for almost-seamless multi-display setups that give you an even greater degree of immersion. An advanced high-performance IPS panel gives you an astonishing 80,000,000:1 contrast ratio and wide 178° viewing angles. In addition, ASUS Eye Care technology ensures a comfortable viewing experience.
  • Ultra-slim profile
    VZ27AQ takes up very little desktop space and fits well in any setting.
  • See better with WQHD resolution
    Prepare to be amazed as you experience exceptional 2560 x 1440 resolution visuals with the VZ27AQ. With its 27" WQHD display, VZ27AQ gives you sharper images and more onscreen space than a similarly sized Full HD display - allowing you the freedom to spread out your various desktop windows.
  • Perfect for multi-display setups
    Whether you're playing games, watching a movie, or getting some work done, VZ27AQ's frameless design means two or three monitor setups are virtually seamless, giving you a panoramic display for an even greater degree of immersion.
  • Ultra-low Blue Light monitor
    The ASUS Blue Light Filter protects you from harmful blue light, and you can easily access its four different filter settings via a hotkey.
  • Flicker-Free technology
    It's time to say goodbye to those tired, strained eyes. VZ27AQ features ASUS Flicker-Free technology to reduce flicker for a comfortable viewing experience. This technology helps minimize instances of eyestrain and other damaging ailments, especially when you spend long, countless hours in front of a display watching favorite videos.
  • Wide 178° viewing angles
    VZ27AQ has an advanced high-performance IPS panel that provides an astonishing 80,000,000:1 contrast ratio and wide 178°viewing angles. This LED-backlit display covers the entire sRGB color space - ensuring extremely accurate color reproduction for professional-grade photo and video editing, or for home entertainment.
ASUS VZ27AQ - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
24 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440
Pixel Pitch
0.233 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
1.074 billion colours (10-bit)
Colour Gamut
100% sRGB
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Black, icicle gold
61.27 cm x 21 cm x 44.08 cm
4.26 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, KCC, WEEE, J-MOSS, ErP Ready, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification
3-year warranty
Display Type
Energy Class
Class A
35 kWh
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440
Pixel Pitch
0.233 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
100% sRGB
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
49 - 76 Hz
Horizontal Refresh Rate
29 - 130 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Ultra Slim Design, HDCP, frameless, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS GamePlus, Low Blue Light Mode, Flicker Free technology, ASUS EyeCare Technology, Blue Light Filter technology, Adaptive-Sync technology, Colour Temperature Selection
Black, icicle gold
61.27 cm x 21 cm x 44.08 cm - with stand
4.26 kg
Audio
Speakers - stereo
Output Power / Channel
1.5 Watt
VGA , HDMI , DisplayPort , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+22
1 x VGA cable , 1 x audio cable
24 W
Power Consumption (Off Mode)
0.5 Watt
Dimensions & Weight Details
Without stand - width: 61.27 cm - depth: 3.655 cm - height: 36.82 cm , With stand - width: 61.27 cm - depth: 21 cm - height: 44.08 cm - weight: 4.26 kg
Shipping Width
68.9 cm
Shipping Depth
11.7 cm
Shipping Height
54.4 cm
Shipping Weight
5.295 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
