Asus VX279H-W 27" 1920x1080 5ms VGA HDMI IPS Monitor
Quicklinx: BJWPWS00 Mfr#: VX279H-W
Inspired by millennia of artistic legacy, VX279H sports an elegant and precision-crafted sundial design. The VX279H features an edge-to-edge frameless panel with 178° ultra-wide viewing angle AH-IPS A+ panel for incredible visuals. It's ultra-slim and ergonomic design can be tilted to provide you comfortable viewing experiences, while dual HDMI/MHL ports offers extensive connectivity options.
  • Extensive connectivity and built-in stereo speaker for multimedia enjoyment
    VX279H comes with rich connectivity including dual HDMI/MHL ports and D-sub so that users could easily share MHL mobile devices content on a much bigger screen as well as charging MHL devices simultaneously. Also connect VX279H with Full HD Blu-ray Disc players and myriad HD playback devices like DVD players and set-top boxes for limitless entertainment and multimedia enjoyment with the built-in stereo speakers.
  • Vivid, lifelike visuals
    VX279H features a 16:9 aspect ratio LED-backlit AH-IPS A+ panel with a 178° wide-view angle that minimizes color shift on both horizontal and vertical planes to ensure quality visuals from almost any direction. AH-IPS is the latest in IPS technology - delivering improved color accuracy plus increased energy efficiency.
  • ASUS smart contrast ratio
    With ASUS Smart Contrast Ratio (ASCR) of 80,000,000:1 and 250cd/m² brightness, VX279H augments display contrast and sharpness by adjusting backlighting luminance to achieve the deepest blacks and brightest whites for truly lifelike visuals.
  • ASUS-exclusive VividPixel technology
    The VividPixel Technology enhances outline, sharpness, and color saturation of images and videos to deliver high-quality visual experience.
  • Splendid video intelligence technology
    The exclusive Splendid Video Intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes can be selected via a hotkey. To deliver a more comfortable viewing experience, ASUS Eyecare monitors adopts Flicker-Free Technology to clear out the distracted flicker shown on the screen and help reduce eye fatigue for long-period watching.
ASUS VX279H-W - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
33 kWh
Power Consumption (On mode)
23 W
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
80000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
AC 120/230 V (50 - 60 Hz)
White
62.26 cm x 21.01 cm x 44.13 cm
4.6 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, ErP Ready, CEL level 1
Display Type
Energy Class
Class A+
33 kWh
Diagonal Size
27"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, input select, colour temperature
HDCP, frameless, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, Mobile High-Definition Link (MHL), ASUS GamePlus, ASUS VividPixel Technology, Slim Design
White
62.26 cm x 21.01 cm x 44.13 cm - with stand
4.6 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1.5 Watt
2 x MHL / HDMI , VGA , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
1 x audio cable , 1 x VGA cable
Security Slot Type
Kensington security slot
Power Supply
External
Input Voltage
23 W
Power Consumption (Typical)
29.1 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Sustainability Information
ENERGY STAR Certified
