Asus VX239H 23" LED IPS 1920x1080 5ms VGA HDMI LCD Monitor
Quicklinx: 9MN3WS00 Mfr#: VX239H
Inspired by millennia of artistic legacy, the VX239H monitor sports an elegant and precision-crafted sundial design. The VX239H features an edge-to-edge frameless panel with 178° ultra-wide viewing angle AH-IPS A+ panel for incredible visuals. Its ultra-slim and ergonomic design can be tilted to provide you comfortable viewing experiences, while dual HDMI/MHL ports offer extensive connectivity options.
  • Superior image quality meets frameless elegant design
  • IPS technology with 178° wide-view angles
    The VX239H monitor features a 16:9 aspect ratio LED-backlit AH-IPS A+ panel with a 178° wide-view angle that minimizes color shift on both horizontal and vertical planes to ensure quality visuals from almost any direction. AH-IPS technology delivers improved color accuracy plus increased energy efficiency.
  • 80,000,000:1 ASUS Smart Contrast Ratio
    With ASUS Smart Contrast Ratio (ASCR) of 80,000,000:1 and 250cd/m² brightness, VX239H augments display contrast and sharpness by adjusting backlighting luminance to achieve the deepest blacks and brightest whites for truly lifelike visuals.
  • ASUS exclusive VividPixel technology
    The VividPixel technology enhances outline, sharpness, and color saturation of images and videos to deliver high-quality visual experience.
  • Splendid Video Intelligence technology
    The exclusive Splendid Video Intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes (Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey.
  • QuickFit Virtual Scale for true what you see is what you get
    ASUS includes its exclusive QuickFit Virtual Scale feature with the VX239H, allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size.
ASUS VX239H - LCD monitor - Full HD (1080p) - 23"
LCD monitor - 23"
Energy Class
Class A
Energy Consumption per Year
27 kWh
Power Consumption (On mode)
18.5 W
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
80000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
53.29 cm x 21.01 cm x 38.98 cm
3.8 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, GOST-R, ErP Ready, CEL
Display Type
LCD monitor / TFT active matrix
Energy Class
Class A
27 kWh
Diagonal Size
23"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Controls & Adjustments
Volume, brightness, contrast, input select, colour temperature
sRGB colour management, HDCP, frameless, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, Mobile High-Definition Link (MHL), ASUS GamePlus, ASUS VividPixel Technology
53.29 cm x 21.01 cm x 38.98 cm - with stand
3.8 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
2 x HDMI , VGA , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
1 x audio cable , 1 x VGA cable
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
18.5 W
Power Consumption (Typical)
40 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Sustainability Information
ENERGY STAR Certified
