ASUS VW199DR dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images.
Indulge your visual senses with 1440 x 900 resolution and 5 ms quick response time for work and entertainment. The best dual-display companion with your widescreen notebook enlarges the visual space for multi-tasking efficiency. Aspect control function allows users to select a preferred display mode among full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
50,000,000:1 ASUS smart contrast ratio
Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images. -
Excellent visual performance
Indulge your visual senses with 1440 x 900 resolution and 5 ms quick response time for work and entertainment. The best dual-display companion with your widescreen notebook enlarges the visual space for multi-tasking efficiency. Aspect control function allows users to select a preferred display mode among full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion. -
Splendid video intelligence technology
The exclusive Splendid video intelligence technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes (scenery, theater, game, night view, sRGB and standard) can be selected via a hotkey.
- ASUS VW199DR - LED monitor - 19"
- LED-backlit LCD monitor - 19"
- Native Resolution
- 1440 x 900
- Pixel Pitch
- 0.2835 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 50000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- VGA
- Tilt
- Black
- 44.4 cm x 21 cm x 36.4 cm
- 4.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, TUV GS, VCCI, C-Tick, BSMI, cUL, NOM, WHQL, CB, CCC, TUV Ergo, PSB, FCC, RoHS, ISO 9241-307, GOST-R, J-MOSS
- 3-year warranty
- Display Type
- Diagonal Size
- 19"
- Native Resolution
- 1440 x 900
- Pixel Pitch
- 0.2835 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 80 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, colour temperature, aspect control
- ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode
- Black
- 44.4 cm x 21 cm x 36.4 cm - with stand
- 4.2 kg
- VGA
Mechanical
- Tilt
- Tilt Angle
- 25
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), wall mountable, cable organizer
- Cables Included
- 1 x VGA cable
- Power Consumption (Typical)
- 27 Watt
- Power Consumption Stand by / Sleep
- 0.1 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
