Asus VT168H 15.6" 1366 x 768 Touchscreen HDMI, VGA Monitor
Quicklinx: CW35WS00 Mfr#: VT168H
The ASUS VT168H touchscreen monitor combines 10-point multi-touch capability with superb image quality, flexible connectivity and great ergonomics. The precise and accurate multi-touch display - allowing up to 10 simultaneous touches - is optimized for use with Windows 10, allowing you to work smarter and more efficiently.
ASUS Splendid Video Intelligence technology employs a color engine with six preset modes. These allow you to adjust your display easily for the best color accuracy and image fidelity, depending on what kind of content is being displayed. You can access the presets via a designated hotkey.
VT168H has undergone stringent performance tests and is awarded Flicker-free and Low Blue Light certifications by TÜV Rheinland laboratories, a global provider of technical, safety, and certification services, toshow display quality with clear image and prevent users suffering from eye strain and fatigue.
  • 10-point multi-touch - an incredibly intuitive touch experience
  • The touchscreen monitor that gives you much more
  • Protect your eyes with ASUS Eye Care technology
  • Ultra-low blue light monitor
    The TUV Rheinland-certified ASUS Blue Light Filter protects you from harmful blue light, and you can easily access its four different filter settings via a hotkey. VT168H has undergone stringent performance tests and has been certified by TUV Rheinland laboratories, a global provider of technical, safety, and certification services, to be flicker-free and to emit low blue light levels.
  • Flicker-free technology
    It's time to say goodbye to those tired, strained eyes. VT168H features TUV Rheinland-certified ASUS Flicker-Free technology to reduce flicker for a comfortable viewing experience. This technology helps minimize instances of eyestrain and other damaging ailments, especially when you spend long, countless hours in front of a display watching favorite videos.
ASUS VT168H - LED monitor - 15.6"
LED-backlit LCD monitor - 15.6" - touchscreen
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/365429
Energy Class
Class D
Energy Consumption per Year
12 kWh
Power Consumption (On mode)
7.9 W
Aspect Ratio
16:9
Native Resolution
1366 x 768
Pixel Pitch
0.252 mm
Brightness
200 cd/m²
Contrast Ratio
50000000:1 (dynamic)
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Voltage
37.78 cm x 18.94 cm x 28.07 cm
1.4 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, VCCI, C-Tick, BSMI, WHQL, CB, TUV Ergo, PSB, RoHS, KCC, WEEE, MEPS, J-MOSS, ErP Ready, E-Standby, UkrSEPRO, KC, RCM, CU-EAC, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification
Display Type
Energy Class
Class D
12 kWh
Diagonal Size
15.6"
Aspect Ratio
16:9
Native Resolution
1366 x 768
Pixel Pitch
0.252 mm
Brightness
200 cd/m²
Contrast Ratio
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
LED backlight
HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, glare, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, Smart View Technology, ASUS QuickFit Virtual Scale, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, ASUS EyeCare Technology, Blue Light Filter technology, Colour Temperature Selection
37.78 cm x 18.94 cm x 28.07 cm - with stand
1.4 kg
Input
Touchscreen
VGA , HDMI , Micro-USB
Mechanical
Tilt
Tilt Angle
-5/+30
VESA Mounting Interface
75 x 75 mm
1 x VGA cable , 1 x HDMI cable , 1 x micro-USB cable
Input Voltage
7.9 W
7.9 kWh/1000h
Power Consumption (Typical)
7 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Microsoft Windows 7 / 8.1 / 10
Dimensions & Weight Details
Without stand - width: 33.78 cm - depth: 4.4 cm - height: 23.59 cm , With stand - width: 37.78 cm - depth: 18.94 cm - height: 28.07 cm - weight: 1.4 kg
Shipping Width
43.38 cm
Shipping Depth
12.2 cm
Shipping Height
34.97 cm
Shipping Weight
2.8 kg
Sustainability Information
ENERGY STAR Certified
