Asus VP278H 27" LED Full HD Monitor 1MS VGA 2x HDMI VGA
Quicklinx: CW0JWS00 Mfr#: VP278H
VP278H 27" Full HD monitor with 100,000,000:1 high contrast ratio, ASUS-exclusive SplendidPlus and VividPixel technologies is optimized for the finest image and color quality. This approach extends to the study stand and slim profile without compromising style in ensuring stability and durability.
  • Superior image quality meets classic elegant design
  • ASUS-exclusive GamePlus Technology
    When it comes to design, ASUS always have customers in mind - the ASUS VP278H features the ASUS-exclusive GamePlus hotkey with crosshair and timer functions. Gamers can select four different crosshair types to suit the gaming environment; while the latter keeps players aware of the elapsed time in real-time strategy games. These tools allow gamers to practice and improve on their gaming skills.
  • 1ms quick response time
    1ms (GTG) quick response time eliminates ghosting and tracers for more fluid video playback.
  • VividPixel Technology for best picture quality
    ASUS VividPixel Technology helps enhance image outlines and reduce noise bars for crystal-clear and detail-oriented viewing.
  • Protect your eyes with ASUS Eye Care Technology
    The VP278H has undergone stringent performance tests and is certified by TÜV Rheinland laboratories, a global provider of technical, safety, and certification services, to be flicker-free and to emit low blue light levels.
ASUS VP278H - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/365424
Energy Class
Class F
Energy Consumption per Year
49 kWh
Power Consumption (On mode)
25.9 W
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
64.14 cm x 21.94 cm x 44.45 cm
4.8 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, BSMI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, WEEE, PSE Mark, MEPS, J-MOSS, ErP Ready, RCM, CEL level 1, TUV Rheinland Low Blue Light Certification
3-year warranty
Display Type
Energy Class
Class F
49 kWh
Diagonal Size
27"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, input select, colour temperature
HDCP, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, Smart View Technology, ASUS QuickFit Virtual Scale, ASUS GamePlus, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, ASUS SplendidPlus Video Intelligence Technology, ASUS EyeCare Technology
64.14 cm x 21.94 cm x 44.45 cm - with stand
4.8 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
2 x HDMI , VGA , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x audio cable
Security Slot Type
Kensington security slot
Input Voltage
25.9 W
25.9 kWh/1000h
Power Consumption (Typical)
29.1 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Dimensions & Weight Details
Without stand - width: 64.14 cm - depth: 5.5 cm - height: 38.31 cm , With stand - width: 64.14 cm - depth: 21.94 cm - height: 44.45 cm - weight: 4.8 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
