Asus VC279H 27" 1920x1080 5ms VGA DVI HDMI IPS Monitor
27", SLIM BEZEL, IPS MONITOR
Quicklinx: BJWKWS00 Mfr#: VC279H
VC279 series feature with In-Plane Switching technology panel with a 178° wide-view angle that minimizes color shift on both horizontal and vertical planes to ensure quality visuals from almost any direction. The VividPixel Technology enhances outline, sharpness, and color saturation of images and videos to deliver high-quality visual experience.
  • Exclusive GamePlus function
    Exclusive GamePlus function hotkey to enable OSD crosshair and timer functions. Select from four different crosshair to suit your gaming environment, and keep track of spawn and build times with the on-screen timer.
  • The latest IPS technology with wide-view angles
  • ASUS smart contrast ratio
    With ASUS Smart Contrast Ratio (ASCR) of 80,000,000:1 and 250cd/m² brightness, VC279H augments display contrast and sharpness by adjusting backlighting luminance to achieve the deepest blacks and brightest whites for truly lifelike visuals.
  • ASUS-exclusive VividPixel technology
  • QuickFit Virtual Scale for true what you see is what you get
    ASUS includes its exclusive QuickFit Virtual Scale feature with the VC279, allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size.
ASUS VC279H - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
21 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
AC 120/230 V (50 - 60 Hz)
62.26 cm x 20 cm x 44.2 cm
4.4 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, ErP Ready, CEL level 1
3-year warranty
Display Type
Energy Class
Class A+
31 kWh
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, colour temperature
HDCP, frameless, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, ASUS GamePlus, ASUS VividPixel Technology, Slim Design, Low Blue Light Mode, Flicker Free technology, ASUS EyeCare Technology
62.26 cm x 20 cm x 44.2 cm - with stand
4.4 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1.5 Watt
DVI-D , VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x DVI cable
Power Supply
External
Input Voltage
21 W
Power Consumption (Typical)
29.1 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 62.26 cm - depth: 4.65 cm - height: 37.26 cm , With stand - width: 62.26 cm - depth: 20 cm - height: 44.2 cm - weight: 4.4 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
