Asus USB-N13 300Mbps 802.11n USB Wireless Adapter, consistent transmission and wide coverage
Quicklinx: 72BSWS00 Mfr#: USB-N13
Wired / Wireless: Wireless
Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Form Factor: External
Compatibility: Mac, PC
Type: Network adapter
  • Windows 8 (32/64 bits)
  • IEEE 802.11n
£18.83 ex VAT
£22.59 inc VAT
The ASUS USB-N13's specially-designed internal antenna provides you consistent transmission and wide coverage. The WPA/WPA2 enterprise encryption enables you to access corporate certificate-based authentication network, ensure that you to communicate under fast and high protected environment.
Xlink Kai is a free software that enables PSP gamers to play system-link games via the Internet instead of via the local area network (LAN). You just enable "PSP Xlink Mode" on ASUS utility, and then wirelessly game with faraway players through Xlink server.
When you are in business trip, when you like to share your internet access, the USB-N13 build-in software AP enables you to create a small WLAN environment and connect to the internet via ICS (Internet Connection Sharing). Its ACL (Access Control List) and ICS (Internet Connection Sharing) let you easily manage your access authority and quickly turns your PC into a Wireless AP, flexible and convenient.
Simply insert USB-N13 into your computer's USB port and press the WPS button on both the router and USB-N13. Within two steps, a secure and protected wireless connection setting done!
The USB-N13 supports you multiple OS driver to easily go freedom wireless on most aboveground OS.
  • 300Mbps Pro N - secure and excellent connection
  • PSP Xlink Kai support
  • Software AP 2-in-1 device for wireless connection sharing
  • EZ WPS Wi-Fi setup - simply insert, simply connect
  • Support Multiple OS - Windows, Mac and Linux
ASUS USB-N13 - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
802.11b/g/n
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
Linux, Microsoft Windows 2000, Apple MacOS X 10.3, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
Network adapter
External
USB 2.0
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
Frequency Band
2.4 GHz
Max Range Open Space
150 m
Status Indicators
Power, link/activity
Software access point, Wi-Fi Protected Setup (WPS)
Aerial
Antenna
Internal
Antenna Qty
2
1 x USB 2.0 - 4 pin USB Type A
Encryption Algorithm
WPA, WPA2-Enterprise
Software Included
Drivers & Utilities
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: Mac
Compatibility: PC
Brand: Asus
Price Range Ex VAT: 0 - 50
