The ROG Delta S gaming headset delivers impeccably clear, detailed audio to give serious gamers the edge to win. It features industry-leading, hi-fi-grade ESS 9281 with QUAD DAC technology and the ASUS AI Noise-Canceling Microphone. At a total weight of just 300 grams and with ergonomic D-shaped ROG Hybrid ear cushions, ROG Delta S offers unmatched comfort during extended gaming sessions. Its USB-C connector allows you to play on your PC and then jump to your gaming console or mobile device without having to change headsets.
High-resolution ESS 9281 Quad-DAC
The ESS 9281 digital-to-analog converter (DAC) features Quad DAC technology to provide lossless audio processing. Each of its four DACs devotes processing power to a subset of the audible frequency range, from lows, mids, highs to ultra-highs. The four signals are then combined, which produces clearer sound with an impressive 130 dB signal-to-noise ratio that's much higher than any other comparable device in the market. Hear every detail and enjoy crisp, clear sound for a true-to-life audio experience with ROG Delta S. -
Built-in MQA renderer
Master Quality Authenticated (MQA) is an award-winning audio technology that delivers studio-quality sound and reveals every detail of the original recording. MQA Renderer technology in the ROG Delta S headset can connect to an MQA core signal - in global streaming service apps such as TIDAL - to complete the final "unfold" of an MQA music file and provide incredible audio quality. -
AI noise-canceling microphone
The ASUS AI noise-canceling microphone (AI Mic) has a dedicated processor that's designed to reduce over 50 million types of background noise while preserving vocal harmonics for crystal-clear in-game voice communication. Common background noises such as chatter, keyboard clatter and mouse clicks are reduced by up to 95%. -
Multiplatform compatibility
The USB-C connector enables high-fidelity audio experiences with PCs, Mac, mobile devices and game consoles such as Nintendo Switch and Sony PlayStation. -
Crafted for comfort
Compared to oval ear cups, the ergonomic D-shaped ear cups of ROG Delta S closely match the shape of your ears, reducing unnecessary contact areas by up to 20%. The drivers in each ear cup are tilted by 12 degrees, closely matching the natural angle of human ears. The sloped design provides better comfort and also helps improve sound quality by enabling the audio signal to travel directly into the ear canal.
- ASUS ROG Delta S - headset
- Product Type
- Headset - wired - USB, USB-C
- Recommended Use
- Game console, portable electronics, computer
- Additional Functions
- Adjustable RGB lighting, quad DAC
- Black
- Headphones Form Factor
- Full size
- Foldable
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Sound Effects
- 7.1 Channel Virtual Surround Sound
- Audio Specifications
- Frequency Response 20 - 40000 Hz
- Impedance
- 32 Ohm
- Microphone
- Boom
- Microphone Operation Mode
- Uni-directional
- Controls
- Volume, microphone on/mute, light on/off
- 2-year warranty
- Product Type
- 22 cm
- 11.5 cm
- 25.8 cm
- 300 g
- Black
- Recommended Use
Audio Output
- Full size
- Foldable
- Wired
- Sound Output Mode
- Stereo
- Sound Effects
- 20 - 40000 Hz
- Impedance
- 32 Ohm
- Diaphragm
- 50 mm
- Magnet Material
- Neodymium
- In-Cord Volume Control
Microphone
- Boom
- Form Factor
- Headset microphone
- Uni-directional
- Sensitivity
- -40 dB
- 100 - 10000 Hz
Remote Control
- Controls
- Connector Type
- Headset (USB Type-C)
Cable
- Cable Length
- 1.5 m
- Included Accessories
- 2 ear cushions, USB-C to USB-A cable
- Cable Details
- USB cable - 1 m , USB-C cable - 1.5 m , USB-C to USB-A adapter
- Limited warranty - 2 years
