The ASUS ProArt GeForce RTX 4080 Super 16GB blends performance with reliability. With a robust 256-bit memory interface and 16 GB of GDDR6X SDRAM, it delivers exceptional speed and efficiency. The card supports OpenGL 4.6 and is compatible with PCI Express 4.0, offering versatility for various systems. Maximize your visual experience with support for up to 4 monitors and a maximum resolution of 7680 x 4320. The included ProArt accessories, such as the graphics card holder and hook-and-loop fastener, provide additional value and convenience. Whether for creative work or gaming, this graphics card offers the features and performance needed to excel.
Enhanced visuals
Experience image clarity and smooth gameplay with the ASUS ProArt GeForce RTX 4080 Super 16GB, featuring a 256-bit memory interface and 16 GB of GDDR6X SDRAM. The high memory speed of 23 Gbps ensures fast and efficient performance for professional and creative tasks. -
Advanced cooling
Keep your system cool under heavy workloads with the Axial-tech Fan Design and Dual ball Bearing Fans. AUTO-EXTREME technology enhances reliability, ensuring your video card remains operational and efficient even during intense sessions. -
Next-gen gaming
Dive into the future of gaming with 3rd gen Ray Tracing Cores and 4th gen Tensor Cores, powered by NVIDIA Ada Lovelace GPU technology. NVIDIA DLSS 3 optimization means smoother frame rates and better overall gaming experiences, even at maximum settings.
- ASUS ProArt GeForce RTX 4080 Super 16GB - OC Edition - graphics card - NVIDIA GeForce RTX 4080 SUPER - 16 GB
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- Memory
- 16 GB GDDR6X
- Memory Speed
- 23 Gbps
- Core Clock
- 2610 MHz
- Boost Clock (OC)
- 2640 MHz
- CUDA Cores
- 10240
- Memory Interface
- 256-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- HDMI , 3 x DisplayPort
- API Supported
- OpenGL 4.6
- 5 cm x 30 cm x 12 cm
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- Core Clock
- 2610 MHz
- Boost Clock (OC)
- 2640 MHz
- CUDA Cores
- 10240
- VR Ready
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- OpenGL 4.6
- 2.5-slot Fan Cooler, Triple Fan Design, 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, AUTO-EXTREME technology, Axial-tech Fan Design, Dual ball Bearing Fans, NVIDIA Ada Lovelace GPU technology, NVIDIA DLSS 3, Nvidia Studio, NVIDIA Reflex, NVIDIA RTX Video Super Resolution, Nvidia Broadcast, 0dB Technology, reverse airflow, Premium Digital Power Design, vented backplate, Optical Flow Accelerator, NVIDIA G-Sync ready, Resizable BAR, HDCP
- Size
- 16 GB
- Technology
- GDDR6X SDRAM
- Memory Speed
- 23 Gbps
- Bus Width
- 256-bit
- Required Power Supply
- 850 W
- Additional Requirements
- 16 pin PCI Express power connector
- Included Accessories
- Collection card, thank you card, 16-pin to 3x 8-pin cable adapter, hook-and-loop fastener, ProArt graphics card holder
- Software Included
- ASUS GPU Tweak III, ASUS Quantumcloud, NVIDIA GeForce Experience, Adobe Creative Cloud (3 months membership)
- DisplayPort 1.4a, HDCP 2.3
- 5 cm
- 30 cm
- 12 cm
