ASUS Dual GeForce RTX 4060 8GB OC Edition Graphics Card
Quicklinx: HX1SWS00 Mfr#: DUAL-RTX4060-O8G
£261.47 ex VAT
£313.76 inc VAT
ASUS Dual GeForce RTX 4060 fuses dynamic thermal performance with broad compatibility. Advanced cooling solutions from excellent graphics cards - including two Axial-tech fans for maximizing airflow to the heatsink - are packed into a 2.5-slot card, delivering more power in less space. These enhancements make ASUS Dual the perfect choice for gamers who want heavyweight graphics performance in a compact build.
  • Axial-tech fan design
    Two tried-and-true Axial-tech fans feature a smaller hub that facilitates longer blades and a barrier ring to increase downward air pressure.
  • 0dB Technology
    To eliminate unnecessary noise, a stop mode halts all fans when the GPU temp falls below 50 degrees and power consumption is low.
  • Dual Ball Fan Bearings
    Different bearing types have unique pros and cons. Ball bearings excel at durability and can last up to twice as long as sleeve bearing designs.
  • Dual BIOS
    Do you prioritize low core temps or low noise levels? Performance mode will let the fans spin up to keep the card running cool all the time. Quiet mode keeps the same power target and top-end settings, but offers a less aggressive fan curve for quieter operation at medium temps.
  • 2.5-slot design
    A carefully designed shroud, heatsink, and heat pipe layout allows the two Axial-tech fans to leverage chassis side-panel ventilation and deliver thermal performance that belies the card's size.
  • Auto-Extreme Technology
    Auto-Extreme Technology is an automated manufacturing process that sets standards in the industry by allowing all soldering to be completed in a single pass. This reduces thermal strain on components and avoids the use of harsh cleaning chemicals, resulting in less environmental impact, lower manufacturing power consumption, and a more reliable product overall.
  • GPU TWEAK III
    The ASUS GPU Tweak III utility takes graphics card tuning to the next level. It allows you to tweak critical parameters including GPU core clocks, memory frequency, and voltage settings, with the option to monitor everything in real-time through a customizable on-screen display. Advanced fan control is also included along with many more features to help you get the most out of your graphics card.
  • Stainless steel bracket
    The mounting bracket of the Dual has been beefed up with stainless steel that's hard and resistant to corrosion.
  • Protective backplate
    The PCB is reinforced by an aluminum backplate that adds structural rigidity, helping to prevent flex and protect components and trace pathways from damage. The rear features a wide vent that allows hot air to escape towards chassis exhaust fans instead of being recycled back into the GPU cooler.
ASUS Dual GeForce RTX 4060 8GB - OC Edition - graphics card - GeForce RTX 4060 - 8 GB
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
NVIDIA GeForce RTX 4060
8 GB GDDR6
Memory Speed
17 Gbps
Boost Clock
2505 MHz
CUDA Cores
3072
Memory Interface
128-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
HDMI , 3 x DisplayPort
API Supported
OpenGL 4.6
4.96 cm x 22.72 cm x 12.324 cm
Package Type
Box
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Boost Clock
2505 MHz
CUDA Cores
3072
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
OpenGL 4.6
NVIDIA Ada Lovelace GPU technology, 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, Axial-tech Fan Design, 0dB Technology, Dual ball Bearing Fans, NVIDIA DLSS 3, NVIDIA Reflex, Nvidia Broadcast, Nvidia Studio, Dual Bios, AUTO-EXTREME technology, aluminium backplate, stainless steel mounting bracket, HDCP
Size
8 GB
GDDR6 SDRAM
Memory Speed
17 Gbps
Bus Width
128-bit
Required Power Supply
550 W
Additional Requirements
8 pin PCI Express power connector, 2 adjacent PCI slots
Collection card
Software Included
ASUS GPU Tweak III, ASUS Quantumcloud, Adobe Creative Cloud (1 month membership)
DisplayPort 1.4a, HDCP 2.3
4.96 cm
22.72 cm
12.324 cm
Package Details
Box
Brand: Asus
