Asus PB278QR 27" 2560x1440 5ms VGA DVI HDMI DisplayPort LED Monitor
Quicklinx: 9TQYWS00 Mfr#: PB278QR
The PB278QR offers a highly ergonomic and smart design that complies with tilt, pivot, swivel, and height adjustments to ensure an always-comfortable viewing and usage experience. Its smart cable management further promotes clutter-free spaces for work and enjoyment. Premium 16:9 wide-format PB278QR LED displays with 178° wide viewing angle panel for better productivity, opening extra multitasking space to fit more windows and projects on-screen. ASUS exclusive Splendid Video Intelligence Technology, QuickFit Virtual Scale, and 100% sRGB fidelity ensure reality-defining color and image accuracy, giving you true "what you imagine is what you create" power. HDMI, DisplayPort, and dual-link DVI support WQHD natively, accentuated by room-dominating audio via twin 3W speakers. To help you stay naturally focused, ergonomic design includes tilt, swivel, pivot, and height adjustment, plus streamlined cabling that keeps clutter off your desktop.
  • Precision to the finest detail
    Envision bigger with 2560 x 1440 WQHD, packing four times the pixel density of 720p! Premium 16:9 wide-format PB278QR LED displays with 178° wide viewing angle panel for better productivity, opening extra multitasking space to fit more windows and projects on-screen. ASUS exclusive Splendid Video Intelligence Technology, QuickFit Virtual Scale, and 100% sRGB fidelity ensure reality-defining color and image accuracy, giving you true "what you imagine is what you create" power. HDMI, DisplayPort, and dual-link DVI support WQHD natively, accentuated by room-dominating audio via twin 3W speakers. To help you stay naturally focused, ergonomic design includes tilt, swivel, pivot, and height adjustment, plus streamlined cabling that keeps clutter off your desktop.
  • See better and wider
    The PB278QR WQHD monitor provides 109 pixels per inch (PPI), resulting in high quality 2560 x 1440 visuals - equaling four times the resolution of standard 720p sets. It allows users to view greater image detail and do more with an onscreen footprint larger than that of standard displays. The screen's 109PPI density means there are 109 RGB matrices within one inch. Generally, the more pixels a display has, the more lighting (or power) those pixels require to achieve the best visuals. However, with advanced LED backlighting on the PB278QR, power and energy savings are no longer compromised, while better visuals are assured.
  • Made for work and play
    The ASUS PB278QR provides an ultra-wide 178° viewing angle on both horizontal and vertical planes, thereby minimizing onscreen color shift even when viewed from extreme angles. With its WQHD display, you enjoy 77% more desktop space than a full HD screen to spread out your windows and palettes. It is also about 25% sharper than a generic 27" full HD display, delivering ultra-smooth visuals thanks to 5ms (GTG) response time. This ensures you get lag-free experiences in movies and gaming, with the latter looking more vivid, with all in-game details shown in true color. The ASUS PB278QR is undoubtedly your best choice for work and play.
  • Native WQHD content support
    The PB278QR features a host of connectivity options that include HDMI, DisplayPort, and dual-link DVI for native WQHD, plus D-sub for full HD 1080p content transmission. The HDMI port also supports MHL which allows you to use the MHL with HDMI connection to view content from your mobile device on the PB278QR while simultaneously charging the mobile device. Twin built-in 3W speakers provide quality audio for a completely immersive home theater experience.
  • QuickFit virtual scale for true what you see is what you get
    ASUS includes its exclusive QuickFit Virtual Scale feature with the PB278QR, allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size.
  • Designed with you in mind
ASUS PB278QR - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
53 kWh
Power Consumption (On mode)
36 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Brightness
300 cd/m²
Contrast Ratio
80000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Gamut
100% sRGB
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Voltage
64.3 cm x 21.8 cm x 55.23 cm
7.8 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, PSE Mark, GOST-R, J-MOSS, ErP Ready
Display Type
Energy Class
Class B
53 kWh
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Pixel Per Inch
109
Brightness
300 cd/m²
Contrast Ratio
Colour Gamut
100% sRGB
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, input select, colour temperature
Picture in picture, picture by picture, Zero Bright Dot, HDCP, ASUS Splendid Video Intelligence Technology, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, Mobile High-Definition Link (MHL), ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, ASUS SplendidPlus Video Intelligence Technology, ASUS EyeCare Technology
64.3 cm x 21.8 cm x 55.23 cm - with stand
7.8 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2.5 Watt
HDMI , DisplayPort , Audio line-in , Headphones , DVI-D (dual link) , VGA
Mechanical
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x audio cable , 1 x DVI cable , 1 x VGA cable
Input Voltage
36 W
Power Consumption (Typical)
30 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Dimensions & Weight Details
Without stand - width: 64.3 cm - depth: 6.96 cm - height: 38.62 cm
Sustainability Information
ENERGY STAR Certified
