Asus PA249Q 24.1" 1920x1200 6ms VGA DVI-D DisplayPort IPS LED Monitor
Quicklinx: 91RVWS00 Mfr#: PA249Q
The ASUS PA249Q LED-backlit monitor offers 10-bit display color for over one billion onscreen colors and support 12 bit internal lookup table (LUT), which gives smoother gradations and a more natural transition between hues. It also features AH-IPS (Advanced High-Performance In-Plane Switching) display technology for superior color accuracy, a brighter image from increased backlight transmission and lower power consumption. An ergonomic design, with tilt, swivel, pivot and height adjustment give users a comfortable viewing experience.
  • Wide color gamut reproduces 99% of the Adobe RGB color space
    The ASUS PA249Q is pre-calibrated at the factory for the highest accuracy and outstanding color space reproduction. With a wide color gamut of 99% Adobe RGB, the colors seen in photos will be reproduced faithfully and consistently.
  • 10-Bit color for smoother gradations
    The PA249Q offers 10-bit display color for over one billion onscreen colors and support 12 bit internal lookup table (LUT), which gives smoother gradations and a more natural transition between hues.
  • Pre-calibrated right out-of-the box
    Each PA249Q have been pre-calibrated to minimize the color difference to Delta E (?E) of less than 3 - ensuring precise reading of color input and guarantees excellent color fidelity.
  • Next-generation IPS display technology
    The ASUS PA249Q features AH-IPS (Advanced High-Performance In-Plane Switching) display technology for superior color accuracy, a brighter image from increased backlight transmission and lower power consumption. Each PA249Q also features a brightness ASUS Smart Contrast Ratio for enhanced image contrast.
  • 6-axis independent color adjustment
    Customized hue and saturation control with 6 color adjustment allows you to adjust six colors (red, green, blue, cyan, magenta and yellow) independently without effecting other colors.
  • Robust connectivity
    The PA249Q comes with four USB 3.0 ports, users can easily plug in their devices and experience ultra-fast data transmission speeds that are up to 10 times that of current USB 2.0 standards. An extensive array of connectivity and high compatibility options are available with the PA249Q, including Display Port, HDMI, DVI, and D-sub; the PA249Q also allows users to use up to two or three displays simultaneously.
  • Splendid Video Intelligence Technology
    ASUS Splendid Video Intelligence Technology is built upon a color engine that automatically analyzes and determines the nature of the user's current task, thereafter adjusting the display's parameters according to ensure color accuracy and image fidelity. Seven preset modes (Scenery, Theater, Adobe RGB, sRGB, standard and two user modes) can be selected via a designated hotkey.
  • Intuitive 5-Way Navigation Key
    The PA249Q has a 5-way navigation key that acts as a joystick that gives access to the Quick Fit Virtual Scale function along with all OSD functions and settings.
  • Customizable OSD Shortcuts
    The PA249Q also features two user-customizable shortcuts for frequently used monitor controls, removing the need to navigate the full onscreen menu system.
  • Picture-in-Picture and Picture-by-Picture
    ASUS exclusive innovations Picture-in-Picture (PIP) and Picture-by-Picture (PBP) allows users to view images from different signals in almost any way they want. PIP and PBP let users view images from different signals and let them switch between the main and PIP source, including audio, easily.
  • Quick Fit Virtual Scale Function
    ASUS included its exclusive Quick Fit Virtual Scale Function with the PA249Q, allowing users to preview photos and documents on screen in their actual sizes prior to printing. It can be activated via a hotkey on monitor and used as a guide to accurately view and edit photos.
  • Ergonomic design
    The PA249Q has an ergonomic design, with tilt, swivel, pivot and height adjustment give users a comfortable viewing experience.
ASUS PA249Q - LED monitor - 24.1"
LED-backlit LCD monitor - 24.1"
Energy Class
Class B
Energy Consumption per Year
45.7 kWh
Power Consumption (On mode)
31.3 W
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
350 cd/m²
Contrast Ratio
80000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
1.07 billion colours
Colour Gamut
100% sRGB, 120% (CIE 1976), 99% Adobe RGB
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Voltage
AC 120/230 V
55.72 cm x 23.5 cm x 41.63 cm
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
UL, VCCI, C-Tick, BSMI, cUL, NOM, WHQL, CB, CCC, TUV Ergo, FCC, RoHS, ISO 9241-307, WEEE, PSE Mark, GOST-R, J-MOSS, ErP Ready
Display Type
Energy Class
Class B
45.7 kWh
Diagonal Size
24.1"
Built-in Devices
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Gamma correction, input select, colour temperature
Picture in picture, picture by picture, HDCP, ASUS Splendid Video Intelligence Technology, anti-glare, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, 5-way Navigation Key, customisable OSD buttons, 10-bit lookup table
55.72 cm x 23.5 cm x 41.63 cm - with stand
VGA , DVI-D , Headphones , DisplayPort , HDMI , 4 x USB 3.0 downstream , USB 3.0 upstream (Type B)
Mechanical
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Cable tie
1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable
Power Supply
Internal
Input Voltage
AC 120/230 V
31.3 W
Power Consumption (Typical)
75 Watt
Power Consumption Stand by
1 Watt
Power Consumption Sleep
0 Watt
On / Off Switch
Included Software
Drivers & Utilities
Dimensions & Weight Details
Without stand - width: 55.72 cm - depth: 6.2 cm - height: 36.28 cm
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
