Asus PA248Q 24" IPS Monitor
Quicklinx: 8BQ6WS00 Mfr#: PA248Q
The PA248Q ProArt Series LCD display is a design professional-grade monitor that delivers excellent color fidelity and reproduction along with exclusive productivity features such as four USB 3.0 ports.
  • Excellent color reproduction from every angle
    The ASUS PA248Q is ideal for photography and design professionals and is precision calibrated straight from the factory to deliver superior color fidelity right out of the box. It features a 16:10 aspect ratio, 1920 x 1200 IPS LED-backlit panel for 100% sRGB color reproduction along with a 178° wide view angle to ensure quality visuals and minimal onscreen color shift from almost any viewing position.
  • The world's first monitor with four USB 3.0 ports
    The PA248Q sets a standard by being the world's first monitor with four USB 3.0 ports; users can easily plug in their devices and experience ultra-fast data transmission speeds that are up to 10 times that of current USB 2.0 standards. An extensive array of connectivity and compatibility options are available with the PA248Q including DisplayPort, HDMI, DVI, and D-sub; the PA248Q also allows users to use up to two or three displays simultaneously.
  • ASUS-exclusive features and design
    ASUS included its exclusive QuickFit virtual scale function with the PA248Q, allowing users to preview photos and documents on screen in their actual sizes. QuickFit virtual scale supports A4, letter, 8" x 10", 5" x 7", 4" x 6", 3" x 5", and 2" x 2" sizes. It also has alignment, centimeter and inch-based grids for added flexibility. QuickFit can be activated via a simple hotkey. The PA248Q also provides users with the choice of seven different background colors to select.
  • Ergonomic, award-winning design
    As with most ASUS displays, the PA248Q has an ergonomic design, with tilt, swivel, pivot and height adjustment to give users a comfortable viewing experience.
ASUS PA248Q - LED monitor - 24.1"
LED-backlit LCD monitor - 24.1"
Energy Class
Class A+
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
19.9 W
5-way joystick, USB 3.0 hub
Panel Type
IPS
Native Resolution
Full HD WUXGA 1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Voltage
55.72 cm x 23.5 cm x 41.63 cm
6.4 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
UL, TUV GS, VCCI, C-Tick, BSMI, cUL, NOM, WHQL, CB, CCC, TUV Ergo, PSB, FCC, RoHS, ISO 9241-307, GOST-R, J-MOSS, ErP Ready
Display Type
Energy Class
Class A+
29 kWh
Diagonal Size
24.1"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Native Resolution
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
Picture in picture, HDCP, ASUS Splendid Video Intelligence Technology, anti-glare, Trace Free Technology, ASUS Splendid Video Preset Mode, Color Rich Technology, 72% NTSC colour gamut
55.72 cm x 23.5 cm x 41.63 cm - with stand
6.4 kg
Input
5-way joystick
VGA , DVI-D , Headphones , DisplayPort , HDMI , 4 x USB 3.0 downstream , USB 3.0 upstream (Type B)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
120
Rotation Angle
90
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
Cable tie
1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
19.9 W
Power Consumption (Typical)
19.91 Watt
Power Consumption Stand by / Sleep
1 Watt
On / Off Switch
Dimensions & Weight Details
Without stand - width: 55.72 cm - depth: 6.2 cm - height: 36.28 cm , With stand - width: 55.72 cm - depth: 23.5 cm - height: 41.63 cm - weight: 6.4 kg
Shipping Width
68.1 cm
Shipping Depth
29.2 cm
Shipping Height
43.9 cm
Shipping Weight
9.9 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
