The 15.6-inch MB168B+ portable USB-powered monitor needs just one USB cable for both its video signal and power to deliver up to a Full HD resolution. Thanks to the higher bandwidth of USB 3.0, experience fast, fluid images from your connected device that makes having an on-the-go multi-display setup a reality. What's more, the MB168B+ is backwards compatible with a notebook or desktop PC USB 2.0 port.
Sleek and ultra-portable with a Zen-inspired design
With a slim 8 mm (0.3-inch) profile and tipping the scales, the MB168B+ is the world's slimmest and lightest companion display, ideal for a simple on-the-go dual-monitor setup and mobile presentations. A durable metallic finish with a fine pattern of concentric circles makes the MB168B+ the perfect complement to your notebook. And for added durability, it comes with a protective carrying case that doubles as an adjustable stand for tabletop use. -
Adjusting to your needs
The MB16SB+ automatically senses its orientation and switches the display between landscape and portrait based on its position; while backlight brightness is also automatically adjusted based on environmental lighting-getting brighter in the light and dimmer in the dark. -
Increased productivity with ASUS EzLink technology
The MB168B+ features ASUS EzLink technology that offloads graphics processing from the PC to dedicated hardware in the monitor. As a result, a PC can drive up to five MB168B+ monitors at the same time, regardless of its own graphics capability - it just needs sufficient USB ports. EzLink also automatically restores application window positions as a MB168B+ monitor is connected and disconnected, and automatically rotates the image between landscape and portrait modes, as required.
- ASUS MB168B+ - LED monitor - Full HD (1080p) - 15.6"
- LED-backlit LCD monitor - 15.6"
- Power Consumption (On mode)
- 6.16 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.179 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 600:1 (dynamic)
- Response Time
- 11 ms
- Colour Support
- 262,000 colours
- Input Connectors
- USB
- Black/silver
- 37.9 cm x 0.8 cm x 23.6 cm
- 800 g
- UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, PSE Mark
- 3-year warranty
- Display Type
- Diagonal Size
- 15.6"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.179 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 600:1 (dynamic)
- Colour Support
- 262,000 colours
- Response Time
- 11 ms
- Horizontal Viewing Angle
- 140
- Vertical Viewing Angle
- 120
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness
- ASUS AI Light, ASUS EzLink technology
- Black/silver
- 800 g
- USB 3.0
- Included Accessories
- Carrying case with display stand
- Cables Included
- 1 x SuperSpeed USB cable
- 6.16 W
- Power Consumption (Typical)
- 5 Watt
- Power Consumption Stand by
- 0.58 Watt
- Power Consumption Sleep
- 0.41 Watt
- Included Software
- Drivers & Utilities
- OS Required
- Microsoft Windows 7, Apple MacOS X 10.8.3 or later
- Limited warranty - 3 years
