ASUS GeForce® GTX 970 DC Mini small form factor gaming graphics card
- 1228 MHz engine clock for better performance and outstanding gaming experience
- DirectCU Mini with vapor chamber offers 20% cooler and Vastly quieter performance
- DirectCU Mini measures just 17cm in length -making it the perfect choice for compact gaming PCs
- Premium alloys in power delivery components defeat heat for cards that run 15% faster and last 2.5 times longer than reference
- GPU Tweak helps you modify clock speeds, voltages, fan performance and more, all via an intuitive interface
- GPU Tweak Streaming share on-screen action in real time - so others can watch live as games are played
Go mini. Game Big.
small form factor PCs based on mini ITX motherboards are a popular choice for gamers and home users. Their compact cases are much easier to transport to LAN parties than a standard desktop PC, and stylish designs with comparatively low power requirements make them a natural choice for home theater PCs. The ASUS GeForce® GTX 970 DirectCU Mini is designed to maximize the potential offered by mini ITX motherboards by delivering high performance graphics. It uses an innovative DirectCU thermal design that combines a heat-spreading vapor chamber and the CoolTech Fan, which uses wide-angle airflow and venting to cool critical graphics card components.
DirectCU Mini: 20% cooler Vastly quieter
Award-winning DirectCU now includes custom vapor chamber technology and the new and advanced 360-degree CoolTech axial fan. Even in DirectCU Mini form, the proprietary design delivers up to 20% cooler temps and vastly quieter performance than reference.
Super Alloy Power: Enhanced durability and cooling
Exclusively-formulated alloy components boost performance by reducing power loss, enhancing durability, and achieving cooler operation. Choke concrete cores eliminate buzzing sound under full load while capacitors assure a 50,000-hour lifespan: equivalent to 2.5 times longer than traditional capacitors.
Go mini, game big
The small form factor PCs based on mini ITX motherboards are a popular choice for gamers and home users. Their compact cases are much easier to transport to LAN parties than a standard desktop PC, and stylish designs with comparatively low power requirements make them a natural choice for home theater PCs. The ASUS GeForce GTX 970 DirectCU mini is designed to maximize the potential offered by mini ITX motherboards by delivering high performance graphics. It uses an innovative DirectCU thermal design that combines a heat-spreading vapor chamber and the CoolTech fan, which uses wide-angle airflow and venting to cool critical graphics card components. -
DirectCU mini - 20% cooler vastly quieter
Award-winning DirectCU now includes custom vapor chamber technology and the advanced 360-degree CoolTech axial fan. Even in DirectCU mini form, the proprietary design delivers up to 20% cooler temps and vastly quieter performance than reference. -
Super Alloy Power - enhanced durability and cooling
Exclusively-formulated alloy components boost performance by reducing power loss, enhancing durability, and achieving cooler operation. Choke concrete cores eliminate buzzing sound under full load while capacitors assure a long lifespan: equivalent to 2.5 times longer than traditional capacitors. -
Small form factor for ITX builds
DirectCU mini measures just 17 cm in length - making it the perfect choice for compact gaming PCs. -
GPU Tweak with streaming - real-time intuitive graphics tuning
Shows detailed specs and actual card status with GPU-Z; monitoring widget provides real-time detailed multi-parameter info; automatically checks and updates drivers and BIOS versions. -
Stream online instantly
GPU Tweak streaming tool that lets you share on-screen action in real time - so others can watch live as games are played. It's even possible to add to the streaming window scrolling text, pictures and webcam images.
- ASUS GTX970-DCMOC-4GD5 - graphics card - GF GTX 970 - 4 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 970
- Memory
- 4 GB GDDR5
- Core Clock
- 1088 MHz
- Boost Clock
- 1228 MHz
- CUDA Cores
- 1664
- Effective Memory Clock
- 7.01 GHz
- Memory Interface
- 256-bit
- Max Resolution
- 4096 x 2160
- Interfaces Details
- DVI-I (dual link) , DVI-D , HDMI , DisplayPort
- 4.07 cm x 17 cm x 12.19 cm
- Microsoft Certification
- Compatible with Windows 7
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1088 MHz
- Boost Clock
- 1228 MHz
- CUDA Cores
- 1664
- Max Resolution
- 4096 x 2160
- Nvidia PhysX-Ready, Nvidia 3D Vision technology, Super Alloy Power technology, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, ASUS DirectCU Mini Technology, GPU Tweak Streaming, HDCP
- Size
- 4 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 7.01 GHz
- Bus Width
- 256-bit
- Software Included
- ASUS GPU Tweak
- 4.07 cm
- 17 cm
- 12.19 cm
