Asus GeForce GTX 560 Ti 448 Cores 732MHz 1GB PCI-Express HDMI
SALE! WAS £191.66
Quicklinx: 7TC4WS00 Mfr#: ENGTX560TI448DC2/2DIS/128
  • High-Definition Multimedia Interface (HDMI)
Dunc's Deal Alert
During August 2012 anyone who buys one of these Asus GTX 560 Ti 448 Cores 732MHz Graphics Cards will be able to claim a FREE download voucher for Shogun 2 Total War on PC. Simply order the item and then email duncsdeals@dabs.com with your Sales Order Number to claim, a code will be emailed back within 48 hours
Asus ENGTX560Ti448 DC2/2DIS/1280MD5 Nvidia GTX560Ti448, Super Alloy Power for 15% performance increase, 2.5 times longer product lifespan and 35C cooler operation.
Get Ready for a 20% Cooler Experience with the Dual Fan GTX560Ti448 DirectCU 2
ASUS is proud to introduce the new ASUS ENGTX560Ti448 DC2 to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35°C cooler operation. In addition to this, the engine clock runs at a staggering 732MHz, allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX560TI448 DC2 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive GPU Tweak technology also being a key feature of this product, the ENGTX560Ti448 DC2 covers users for every possible over-clocking and over-volting scenario.
ASUS Unique Selling Points
  • GPU Tweak: Overclocking tool co developed with GPUZ.
  • DirectCU II Cooling: Dual fan cooler design with direct copper heatpipes on GPU surface for up to 20% cooler operation.
  • Super Alloy Power: Provides 15% performance increase, 2.5 times longer product lifespan and 350C cooler operation.
Key Selling Points
  • Microsoft Windows 7 Support: Enable PC users to enjoy an advanced computing experience.
  • DirectX 11 Ready: Bring new levels of visual realism to gaming.
  • SLI Support: Multi GPU Technology for Extreme performance.
  • NVIDIA 3D Vision™ Ready: The only full 1080p HD solution for 3D games, 3D movies and 3D pictures.
  • NVIDIA PhysX ready: Dynamic visual effects like blazing explosions, reactive debris, realistic water, and lifelike characters.
  • GeForce® CUDA Support: Unlocks the power of GPU's processor cores to accelerate the most demanding system tasks.
  • DisplayPort Supported: Next Generation high performance digital connectivity.
Key specification
  • Graphics Engine GeForce® GTX560 Ti 448 Cores
  • Bus Standard PCI Express® 2.0
  • Video Memory 1280MB GDDR5
  • Engine Clock 732 MHz
  • CUDA Cores 448
  • Shader Clock 1464 MHz
  • Memory Clock 3800MHz (950MHz GDDR5)
  • Memory Interface 320 bit
  • DVI Max. Resolution 2560 * 1600
  • DSub Max. Resolution 2048 * 1536
  • D-sub Output 1 x DVI-to-D-sub adaptor
  • DVI Output 2 x DVI-I
  • HDMI Output 1 x Native HDMI
  • Display Port: 1 x Native DP
  • HDCP compliant YES
  • Dimension The card size is 11.1" x 4.9" x 2.3 Inches 2.5 Slot
In The Box
  • Accessory bundled
  • 1 x DVI-to-D-sub adaptor
  • 1 x Power Cable
  • 1 x Exclusive 12cm SLI Bridge
  • Software Bundled
  • ASUS Utilities & Driver
  • GPU Tweak
ASUS - GF GTX 560 Ti
